Snoopy11 5,731 #51 Posted March 8, 2022 On 2/14/2022 at 2:55 PM, Snoopy11 said: sounds a bit like a broken rod 43 minutes ago, petermil12833 said: There's (big) debris in the oil sump; I could move it around with a screwdrriver, and you can see it in this pic -- illuminated by the flash. Probably the bottom end of a connecting rod. @petermil12833 Sir, I saw your post in my email, since I follow your thread. You may be better off (for various reasons) buying a new motor from Carroll Stream. https://www.carrollstream.com/16HP-Gas-Engine-With-Electric-Start-B-p/cs190esb.htm You don't even necessarily NEED that much power if you are just doing plowing duties. You could get by quite nicely with a 212 base if that fits your budget better. Relying on shops to fix it right, coupled with the cost of getting it fixed, as well as labor cost... makes me hope that you have deep pockets. Don 1 Share this post Link to post Share on other sites
Handy Don 17,489 #52 Posted March 8, 2022 (edited) 2 hours ago, petermil12833 said: THANKS for all the help here! Wish me luck. I'm sure it was a sinking feeling finding that stuff where it doesn't belong. Good luck with your search. Edited March 8, 2022 by Handy Don Share this post Link to post Share on other sites
RED-Z06 2,720 #53 Posted March 8, 2022 6 minutes ago, Handy Don said: I'm sure it was a sinking feeling finding that stuff where it doesn't belong. Good luck with your search. It is...its a sinking feeling akin to when you think your starter gear is bad and you find the bosses have ripped off the cylinder... Share this post Link to post Share on other sites
petermil12833 16 #54 Posted April 4, 2022 Well, I haven't gone away -- I used those rare warm days to take everything off the engine, and I just sent it away with a local small engine mechanic. We'll work together -- he'll disassemble and evaluate and tell me what parts we need; I'll search for parts; and he'll reassemble. I do have a question -- I've always assumed this engine (on a 520H) was a P220G, but it appears to be a P 20 XSL. What's the difference? I don't see any. Thanks. Share this post Link to post Share on other sites
Handy Don 17,489 #55 Posted April 4, 2022 1 hour ago, petermil12833 said: Well, I haven't gone away -- I used those rare warm days to take everything off the engine, and I just sent it away with a local small engine mechanic. We'll work together -- he'll disassemble and evaluate and tell me what parts we need; I'll search for parts; and he'll reassemble. I do have a question -- I've always assumed this engine (on a 520H) was a P220G, but it appears to be a P 20 XSL. What's the difference? I don't see any. Thanks. Spec is for the 220G. Could it have been swapped by a PO? Share this post Link to post Share on other sites
petermil12833 16 #56 Posted April 4, 2022 Anything is possible. I've learned that this engine is not virgin. But it looks exactly like a P220G except for a badge on the shroud. We're treating it as a P220G. Share this post Link to post Share on other sites
WHX?? 58,217 #57 Posted April 4, 2022 7 minutes ago, petermil12833 said: We're treating it as a P220G I would think that's a safe bet. Have you got a pic of the name plate? Curious to see. Share this post Link to post Share on other sites
petermil12833 16 #58 Posted April 4, 2022 Anything is possible. I've learned that this engine is not virgin. But it looks exactly like a P220G except for a badge on the shroud. We're treating it as a P220G. I don't have a pic of that badge, but I think it was just a marketing ploy. I found a serial number that says it's a P220G. 1 1 Share this post Link to post Share on other sites
lynnmor 9,042 #59 Posted April 4, 2022 3 hours ago, petermil12833 said: I do have a question -- I've always assumed this engine (on a 520H) was a P220G, but it appears to be a P 20 XSL. What's the difference? I don't see any. Thanks. The XSL was the extended service life package. A few parts were better, most important were better valves. If your valves are OK, regrind and reuse. 1 Share this post Link to post Share on other sites
petermil12833 16 #60 Posted April 5, 2022 That's encouraging. Engine only has 600 hrs, so I'm hoping to rebuild once we assess the damage. Tnx. Share this post Link to post Share on other sites
petermil12833 16 #61 Posted May 2, 2022 It's time to write the final chapter in this WH520H / P220G saga. (I started this msg a few minutes ago -- but it disappeared, so I'll start again.) The 20 hp Onan is toast. I began tearing it down and found nasty pieces inside, so I turned it over to a real mechanic for assessment. Today, we got together and he showed me that practically everything inside has been damaged -- pistons, cylinder walls, connecting rods, crankshaft, etc. It was filthy when I got it 8 mos ago (600 hrs) and it has clearly been running too hot. It's not practical to rebuild this beast. So I've kept a few parts -- starter, carb and manifold, flywheel, PTO, stator and trigger, new voltage reg, new fuel pump (electric), and I'm looking for a good, used replacement engine. I prefer another P220G, because I want it to be simple. In the meantime, I have a 30 yr-old Toro-Wheelhorse 314H that has resumed its role as my go-to tractor, so I can take my time to shop for another engine. Both tractors have mower decks and I completely rebuilt the 42-inch snowblower attachment last fall, so I'm pretty committed to this brand. Thanks to everyone for your great suggestions and encouragement. I couldn't have gotten this far without you! RS is a great resource, and I'm sure I'll be back. Til then . . . au revoir. 2 2 Share this post Link to post Share on other sites
Handy Don 17,489 #62 Posted May 2, 2022 (edited) 15 hours ago, petermil12833 said: So I've kept a few parts... Sad to hear it is really dead. Other parts you may want to keep: muffler (if not rusted out), the governor ball spider (especially if it is the version with the tab to lock it in place), and the coil. A while ago I bought an internally broken P220 primarily for its good muffler but I'm happy to have it as a backup "donor" for my P218. Edited May 2, 2022 by Handy Don Share this post Link to post Share on other sites
