petermil12833 16 #1 Posted February 14, 2022 Well here goes my lament. My Onan P220G has seized without warning. No big noise. 600 hrs. Plenty of new oil. 30 seconds before it died, the oil pressure light flickered on and off. Then it just stopped abruptly and won’t turn. I can’t try to tear it down until my barn warms up in the spring, but I’d appreciate any thoughts about what to look for first. I thought I was well prepared for winter in the northeast (see pic). I still have my 314H that has served me so well for 25 years. I had completely rebuilt the snowblower attachment – new bearings, chain, paint, and even a transplanted auger from an older blower. Plus, I now had the 520H that I had acquired over the summer. After a good cleaning, a new fuel pump and voltage regulator, new oil and filters in engine and transmission, it has been running perfectly – sounding happy. Til about Feb. 1. There was no knocking or pounding and it didn’t sound like something wanted to escape from inside. But it sure did stop – fast. The only clue was that oil pressure light, but these lights have been unreliable and I intended to troubleshoot all of them in the spring. Too late. Any suggestions about where to look first? Thanks very much! Peter 1 5 Share this post Link to post Share on other sites
Snoopy11 5,731 #2 Posted February 14, 2022 (edited) Well, it is very hard to tell what exactly it might be. I realize that there wasn't a loud sound... to me it sounds a bit like a broken rod... but my first suggestion I would have is to use a borescope and poke around in the engine... A broken cam would cause it to die suddenly, but shouldn't cause it not to rotate. Could also be a broken cam gear... SOOOOO hard to tell... If the engine doesn't rotate at all, it may be that one of the main bearings failed... Im'ma keep thinking about this one. 30 minutes ago, petermil12833 said: won’t turn Certainly something broken.... Don Edited February 14, 2022 by Snoopy11 1 1 Share this post Link to post Share on other sites
Maxwell-8 4,370 #3 Posted February 14, 2022 Take the sparkplugs out, can you still not turn around the engine by hand? 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #4 Posted February 14, 2022 Just now, Maxwell-8 said: turn around the engine by hand Forward AND reverse rotation. Important to know if the engine will roll back but not forward... or not move at all. Don Share this post Link to post Share on other sites
stevasaurus 23,617 #5 Posted February 14, 2022 @Snoopy11 Don, just a suggestion, but why don't you try editing your post to add the next thought you got 1 minute later. It sure would make it a lot easier to follow. Give it a try. 2 3 Share this post Link to post Share on other sites
Snoopy11 5,731 #6 Posted February 14, 2022 Just now, stevasaurus said: the next thought you got 1 minute later No problem sir. Will do. Don 1 Share this post Link to post Share on other sites
petermil12833 16 #7 Posted February 14, 2022 Yup -- it sure could be any of those things. I do know that it won't rotate in either direction. I'll probably not know anything definitive until it warms up out there -- 18F today. THANKS! 1 Share this post Link to post Share on other sites
roadapples 6,987 #8 Posted February 14, 2022 Sorry about the circumstances, but 2 1 Share this post Link to post Share on other sites
stevasaurus 23,617 #9 Posted February 14, 2022 Do you still have the blower attached...wonder if it could not be something there...maybe mule drive?? 1 Share this post Link to post Share on other sites
petermil12833 16 #10 Posted February 14, 2022 No it's not the blower -- I've already transferred that back to my smaller 314H and cleared the most recent snow. It was not happy, because after sleeting all night, it was like blowing 4 inches of concrete. (Boy, I've grown to hate being on my back on the barn floor in the cold! ) 1 1 Share this post Link to post Share on other sites
stevasaurus 23,617 #11 Posted February 14, 2022 I used to love winter, now I love when those that like it get it. Sounds like you have some experience, so I won't ask anymore about newB stuff. I've had engines just get hot and seize, but if you shut them off right away, they will turn after they cool. Got some good guys looking after you when you get warmer. Welcome to Red Square 4 Share this post Link to post Share on other sites
Maxwell-8 4,370 #12 Posted February 14, 2022 26 minutes ago, petermil12833 said: No it's not the blower -- I've already transferred that back to my smaller 314H and cleared the most recent snow. It was not happy, because after sleeting all night, it was like blowing 4 inches of concrete. (Boy, I've grown to hate being on my back on the barn floor in the cold! ) Maybe it ran to long to lean, What do the sparkplugs say? 2 Share this post Link to post Share on other sites
petermil12833 16 #13 Posted February 14, 2022 I'd used this tractor to mow for several months, then to blow snow after the first couple of small storms. On the day it died, I had run it for about 2 minutes and was 100-ft down the driveway when it quit. It was barely warmed up. That's why I'm baffled. Prior to that, it's been running strong and sounding fine. But until I can take it apart (ugh!) it's all conjecture. 2 Share this post Link to post Share on other sites
OutdoorEnvy 1,807 #14 Posted February 14, 2022 Have you checked the oil for metal debris or you could drain it all out and see what's in it. That wouldn't take long. Also borescope camera's are pretty cheap, like around $25. You could get one of those and check through the spark plug holes or the oil fill tube and see if anything is broke. Based on the short run time you described I'm wondering if the oil was too thick from being cold to be dispersed enough to make the cylinder walls and maybe it got hot a seized with the rings being under load with the blower. If that's the case some marvel mystery oil or ATF soaking the head might free it up. 1 2 Share this post Link to post Share on other sites
petermil12833 16 #15 Posted February 14, 2022 Good idea - I will drain and inspect the oil on the next "warm" day, maybe Thursday. Should look good, because as I prepared the tractor for winter, I changed oil and filter -- probably has 4-5 hours on it. The blower load that day was light; I was just planning to clear 1-2 inch off the pavement so the sun could dry it out. It was also about 30 degrees. If the rings were dry, I would expect to hear that before it stopped. I'm thinking something inside just jammed. Thanks all! Share this post Link to post Share on other sites
SylvanLakeWH 30,594 #16 Posted February 14, 2022 Bummer on the engine but a lot of great ideas already… you’re in the right place! 3 Share this post Link to post Share on other sites
RED-Z06 2,716 #17 Posted February 14, 2022 Oil pump gear could have sheared off, does sound like an oil sieze though, 30 seconds is enough time to do it. Share this post Link to post Share on other sites
squonk 45,531 #18 Posted February 15, 2022 Sent you a link to an Onan repair shop. 1 Share this post Link to post Share on other sites
Bill D 2,598 #19 Posted February 16, 2022 Try pulling the flywheel and checking to see if a magnet came loose and jammed in the stator. I've seen it before. Maybe you'll get lucky. Start on the outside and work your way in. 1 1 Share this post Link to post Share on other sites
petermil12833 16 #20 Posted February 16, 2022 Oh, I like that! Maybe I will get lucky. Thanks. Share this post Link to post Share on other sites
Bill D 2,598 #21 Posted February 16, 2022 5 hours ago, petermil12833 said: Oh, I like that! Maybe I will get lucky. Thanks. Please let us know how you make out. Share this post Link to post Share on other sites
wallfish 19,319 #22 Posted February 17, 2022 On 2/14/2022 at 5:39 PM, OutdoorEnvy said: Have you checked the oil for metal debris Exactly A quick easy place to start (even the cold barn) because if you find metal debris in the oil you can start pricing for a potential rebuild or replacement engine right away. 1 Share this post Link to post Share on other sites
petermil12833 16 #23 Posted February 17, 2022 Today our temps got into the 40s, so I spent some time in the barn. Here's my update. I drained and inspected the oil --- dragged a magnet through it to pick up any debris. On first look, I saw absolutely nothing. I wiped the magnet off and dragged it a second time. This time, I found a few (like 4-5) teeny tiny flecks -- almost invisible, but there. Now, I think an engine with 600 hrs might have a little something in the sump, right? After my first look, I concluded nothing to see here. After looking twice, I'd still say almost nothing. Then I thought I'd try Bill's suggestion to look under the flywheel. BUT HERE I AM STUCK. I cannot remove the shroud from the engine. I've got all the screws out, including those on the bottom, and the throttle/governor mount, the voltage regulator and ignition coil mounts. The shroud is now swinging loose, but there's one more fastener at the top near the back of the engine that I cannot see. Can someone tell me where to look? Thanks! Share this post Link to post Share on other sites
RED-Z06 2,716 #24 Posted February 17, 2022 (edited) 19 minutes ago, petermil12833 said: Today our temps got into the 40s, so I spent some time in the barn. Here's my update. I drained and inspected the oil --- dragged a magnet through it to pick up any debris. On first look, I saw absolutely nothing. I wiped the magnet off and dragged it a second time. This time, I found a few (like 4-5) teeny tiny flecks -- almost invisible, but there. Now, I think an engine with 600 hrs might have a little something in the sump, right? After my first look, I concluded nothing to see here. After looking twice, I'd still say almost nothing. Then I thought I'd try Bill's suggestion to look under the flywheel. BUT HERE I AM STUCK. I cannot remove the shroud from the engine. I've got all the screws out, including those on the bottom, and the throttle/governor mount, the voltage regulator and ignition coil mounts. The shroud is now swinging loose, but there's one more fastener at the top near the back of the engine that I cannot see. Can someone tell me where to look? Thanks! 3/8 head bolt, goes in from the opposite side of the shroud near the center of the engine Edited February 17, 2022 by RED-Z06 Share this post Link to post Share on other sites
petermil12833 16 #25 Posted February 17, 2022 Thanks, I'll give it a shot. I knew I came to the right place! Share this post Link to post Share on other sites
