stegs 327 #1 Posted February 14, 2022 anybody know of a good place to find one. used obviously Kinda thinking that might nice to have when the leaves comes down in the fall let me know where the best spot to look for one. Im already searching marketplace and c.l 1 Share this post Link to post Share on other sites
kwalshy 237 #2 Posted February 14, 2022 Did you place a post under the "Wanted" section of our Classifieds here on the site? 3 Share this post Link to post Share on other sites
stegs 327 #3 Posted February 15, 2022 18 hours ago, kwalshy said: Did you place a post under the "Wanted" section of our Classifieds here on the site? I did not yet. Still debating on it. I was just curious where the best place to look for one 1 Share this post Link to post Share on other sites
kpinnc 14,641 #4 Posted February 15, 2022 (edited) Deck mounted WH blowers are somewhat scarce, and you'll need all the parts including the outer deck pulley to run it. It will work best with a fixed collector like a rear mounted bagger system. The rear mounted WH versions are more rare, but work very well. There are many aftermarket versions, but they typically they have another engine mounted to a trailer. Used models show up on Craigslist fairly often here in NC. New ones are quite expensive for what they are, but do work well so long as you don't have oaks that drop little twigs all year. You'll have to stop and unclog the intake regularly if you do. That applies to most any of the versions mentioned. Or you can make your own. That route has quite a bit of fabrication. There are several versions online. I built one for my father in law that works great, but it is alot of work and I already had a good collector. The pic below was before I added the hoses. Rigid from the deck and flex to the collector. Edited February 15, 2022 by kpinnc 4 2 Share this post Link to post Share on other sites
Horse Newbie 7,395 #5 Posted February 15, 2022 5 hours ago, kpinnc said: Deck mounted WH blowers are somewhat scarce, and you'll need all the parts including the outer deck pulley to run it. It will work best with a fixed collector like a rear mounted bagger system. The rear mounted WH versions are more rare, but work very well. There are many aftermarket versions, but they typically they have another engine mounted to a trailer. Used models show up on Craigslist fairly often here in NC. New ones are quite expensive for what they are, but do work well so long as you don't have oaks that drop little twigs all year. You'll have to stop and unclog the intake regularly if you do. That applies to most any of the versions mentioned. Or you can make your own. That route has quite a bit of fabrication. There are several versions online. I built one for my father in law that works great, but it is alot of work and I already had a good collector. The pic below was before I added the hoses. Rigid from the deck and flex to the collector. I would like to place an order please… 1 1 Share this post Link to post Share on other sites
kpinnc 14,641 #6 Posted February 16, 2022 3 hours ago, Horse Newbie said: I would like to place an order please… Me too LOL. 1 Share this post Link to post Share on other sites
whman01 15 #7 Posted March 29, 2022 I have NOS vac-bagger for sale. I am located in Northern MN. Share this post Link to post Share on other sites
kpinnc 14,641 #8 Posted March 29, 2022 41 minutes ago, whman01 said: have NOS vac-bagger for sale. I am located in Northern MN. You should put an ad in the classified section with pictures. 1 Share this post Link to post Share on other sites
