TJ5208 1,841 #1 Posted February 10, 2022 (edited) Ok guys when I went to pick this tractor up it had no brake well I tightened the brake band down still making no difference just rolls. I tightened the nut on the brake band it seemed to help a little. Now the brake band is dragging. What do I need to tighten? Or is the brake band or drum wore out? I tried to push the tractor no skidding. Just rolling. And the nut on the brake band is at the end of threads won't tighten no more Edited February 10, 2022 by TJ Salyers 1 Share this post Link to post Share on other sites
Achto 29,385 #2 Posted February 10, 2022 Is there any pad left on the brake band? Can you get a picture from the side? 1 Share this post Link to post Share on other sites
TJ5208 1,841 #3 Posted February 10, 2022 Just now, Achto said: Is there any pad left on the brake band? Can you get a picture from the side? Just give me a sec I'll go get one. Share this post Link to post Share on other sites
TJ5208 1,841 #4 Posted February 10, 2022 Here you go. 1 Share this post Link to post Share on other sites
Achto 29,385 #5 Posted February 10, 2022 Looks like there is pad yet. Set the parking brake and try pushing the tractor. Watch the brake hub and see if it is tuning. If it's not turning but the tractor moves, then you may have a sheared key on the brake hub. 3 Share this post Link to post Share on other sites
TJ5208 1,841 #6 Posted February 10, 2022 (edited) The brake hub turns. Edited February 10, 2022 by TJ Salyers 1 Share this post Link to post Share on other sites
TJ5208 1,841 #7 Posted February 10, 2022 I set the parking brake our driveway has a little incline I start the tractor and it rolls down the driveway. 1 Share this post Link to post Share on other sites
Achto 29,385 #8 Posted February 10, 2022 Is the band opening and closing with the brake peddle? 2 Share this post Link to post Share on other sites
TJ5208 1,841 #9 Posted February 10, 2022 Yes the band seem to tighten on the drum. 1 Share this post Link to post Share on other sites
TJ5208 1,841 #10 Posted February 10, 2022 VID_20220210_070731.mp4 1 1 Share this post Link to post Share on other sites
TJ5208 1,841 #11 Posted February 10, 2022 (edited) But the tractor won't stop. Edited February 10, 2022 by TJ Salyers Share this post Link to post Share on other sites
Achto 29,385 #12 Posted February 10, 2022 Seems to be operating correctly. The pad may be warn down too far for the stock adjustments. Remove the adjustment nut and place a larger nut on that will slide over the rod. Put the original adjuster nut on and adjust it again. The larger nut will just be there to take up some space. 4 Share this post Link to post Share on other sites
TJ5208 1,841 #13 Posted February 10, 2022 Could I leave that nut there if it stopped the tractor. I don't think I could or should just gonna listen to you guys. Share this post Link to post Share on other sites
953 nut 59,805 #14 Posted February 10, 2022 Get a new brake lining from Bob, they work a lot better than the ones that came with the tractor. @rmay 5 1 Share this post Link to post Share on other sites
TJ5208 1,841 #15 Posted February 10, 2022 None of us here have a PayPal account. Share this post Link to post Share on other sites
Achto 29,385 #16 Posted February 10, 2022 1 minute ago, TJ Salyers said: Could I leave that nut there if it stopped the tractor Yes, the nut will be used as a spacer. The original nut will not thread on any further. Right? Put a larger nut in front of it as a spacer. 2 Share this post Link to post Share on other sites
TJ5208 1,841 #17 Posted February 10, 2022 My neighbor has a part 416-8 so I guess I'll see if I can get the brake band off that and see if it works. 2 Share this post Link to post Share on other sites
TJ5208 1,841 #18 Posted February 10, 2022 Just now, Achto said: Yes, the nut will be used as a spacer. The original nut will not thread on any further. Right? Put a larger nut in front of it as a spacer. Just didn't know if it's going to hurt anything. Share this post Link to post Share on other sites
TJ5208 1,841 #19 Posted February 10, 2022 But what does it mean when the brake band is dragging the drum. Share this post Link to post Share on other sites
Achto 29,385 #20 Posted February 10, 2022 Just now, TJ Salyers said: Just didn't know if it's going to hurt anything. Will be just fine. Just know that some where down the line you will want to get a new brake lining. It's a temporary fix that will buy you a lot of time. 2 Share this post Link to post Share on other sites
lynnmor 7,803 #21 Posted February 10, 2022 Did you follow the instructions in the owners manual? 2 Share this post Link to post Share on other sites
rmaynard 16,291 #22 Posted February 10, 2022 (edited) 43 minutes ago, TJ Salyers said: None of us here have a PayPal account. PM me I can give you alternate payment methods Edited February 10, 2022 by rmaynard 3 3 Share this post Link to post Share on other sites
TJ5208 1,841 #23 Posted February 10, 2022 (edited) 31 minutes ago, lynnmor said: Did you follow the instructions in the owners manual? Yessir tighten it till it skids then tighten it 1/2 turn. But still won't stop. Edited February 10, 2022 by TJ Salyers 1 Share this post Link to post Share on other sites
rmaynard 16,291 #24 Posted February 10, 2022 1 hour ago, TJ Salyers said: But the tractor won't stop. I don't think I saw whether this is a manual or hydro. If it's hydro and you are not returning to the neutral position, it won't stop. Manual is different. 2 Share this post Link to post Share on other sites
TJ5208 1,841 #25 Posted February 10, 2022 Just now, rmaynard said: I don't think I saw whether this is a manual or hydro. If it's hydro and you are not returning to the neutral position, it won't stop. Manual is different. It's a 520-8 2 Share this post Link to post Share on other sites
