Jhawkins 43 #1 Posted February 8, 2022 WHILE USING MY 520 XI IVE NOTICED THE HYDRO LIFT IS VERY LOUD. EVERYTHING WORKS GREAT, ITS JUST LOUD. IT HAD A NEW FILTER PUT ON IT THIS LAST SUMMER I WAS TOLD. ANY IDEAS ON WHAT I COULD DO? 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #2 Posted February 8, 2022 (edited) 16 minutes ago, Jhawkins said: VERY LOUD Loud in what way? Describe the noise... is it a whining noise? Have you checked the fluid level? Edited February 8, 2022 by Jeff-C175 3 Share this post Link to post Share on other sites
Maxwell-8 4,368 #3 Posted February 8, 2022 Can't hear the hydro lift of my c175 over the engine. Curious what the members have to say. 3 Share this post Link to post Share on other sites
Snoopy11 5,721 #4 Posted February 8, 2022 Wonder if it could be the cold? Don 4 Share this post Link to post Share on other sites
Pullstart 68,407 #5 Posted February 8, 2022 What color is the fluid on the dipstick under the seat? Brown/tan or red? 2 Share this post Link to post Share on other sites
oldlineman 1,580 #6 Posted February 8, 2022 Are you sure the correct filter was installed. Bob 4 Share this post Link to post Share on other sites
Pullstart 68,407 #7 Posted February 8, 2022 21 minutes ago, oldlineman said: Are you sure the correct filter was installed. Bob WIX 51410 or Napa 1410 are the ways to go 4 Share this post Link to post Share on other sites
Jhawkins 43 #8 Posted February 8, 2022 It’s making a whining sound. The fluid is a clear golden color, the filter is correct. 1 Share this post Link to post Share on other sites
Jhawkins 43 #9 Posted February 8, 2022 That all being said the tractor has been neglected. I just got it last summer and it was dirty as could be 1 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #10 Posted February 8, 2022 5 minutes ago, Jhawkins said: a whining sound SOME whining could be considered normal. I've noticed that mine all whine a little if the RPMs aren't high enough. 5 Share this post Link to post Share on other sites
Pullstart 68,407 #11 Posted February 8, 2022 Is the hydro motor on the transmission clean? Does any noise change after the transmission is warmed up? Fluid level is where it should be? 2 Share this post Link to post Share on other sites
Jhawkins 43 #12 Posted February 8, 2022 Fluid is good and I don’t notice any noise from the rear end just from the lift 1 Share this post Link to post Share on other sites
Handy Don 14,886 #13 Posted February 8, 2022 (edited) The whine in Eaton-based hydro lifts that I've seen often comes from the relief valve. Once the lift cylinder has reached "end of travel" in either direction, the fluid pressure rises very quickly so to protect the pump that valve opens to allow the fluid to circulate around the lift cylinder. The very rapid flow of fluid can vibrate the valve and make quite a whine. The other source of whine is during a lift or drop and it comes from the control valve being opened only a small amount. Again--fast fluid vibrates the valve and ... whine! The valve on the 520-H's is part of the control valve. I don't know where it is on the 520xi. So the question is, is your lift whining during the lift/drop or at the end before you release the lever? Are you trying to feather the control? Edited February 8, 2022 by Handy Don 2 1 Share this post Link to post Share on other sites
Jhawkins 43 #14 Posted February 9, 2022 So it is when it reaches the top of lift and before I release the handle to stop lifting 2 Share this post Link to post Share on other sites
Moonshine*Connoisseur 493 #15 Posted February 9, 2022 4 hours ago, Pullstart said: WIX 51410 or Napa 1410 are the ways to go Is this still true for a model 1277 ? 2 Share this post Link to post Share on other sites
AMC RULES 37,250 #16 Posted February 9, 2022 Always believed it to be normal operation. All of mine do it too. 1 1 Share this post Link to post Share on other sites
Snoopy11 5,721 #17 Posted February 9, 2022 Just now, AMC RULES said: Always believed it to be normal operation. All of mine do it too. Was thinking the same thing. Don 2 Share this post Link to post Share on other sites
Pullstart 68,407 #18 Posted February 9, 2022 17 minutes ago, Moonshine*Connoisseur said: Is this still true for a model 1277 ? all hydro models. wix or Napa only. 1 1 Share this post Link to post Share on other sites
Jhawkins 43 #19 Posted February 9, 2022 Ok thanks everyone. Appreciate all of the knowledge on here! 1 Share this post Link to post Share on other sites
Handy Don 14,886 #20 Posted February 9, 2022 1 hour ago, Jhawkins said: So it is when it reaches the top of lift and before I release the handle to stop lifting Normal 2 Share this post Link to post Share on other sites
Jeff-C175 7,207 #21 Posted February 9, 2022 1 hour ago, Handy Don said: Normal I consider that the 'alarm' to let me know when to release the lift handle! 3 2 Share this post Link to post Share on other sites
kpinnc 15,971 #22 Posted February 9, 2022 The manual for the 1100 say to allow up to 10 minutes run time in below freezing weather before actuating or damage may result. Not sure if that's meant to include hydraulics or not. My 520-H won't lift anything for 2-3 minutes after cranking, and that's in warm weather. It's the strongest Eaton tranny I've ever owned and it still does it. I'm guessing cold weather takes several minutes to prime and pressurize. 1 Share this post Link to post Share on other sites
WHX?? 53,081 #23 Posted February 9, 2022 17 hours ago, AMC RULES said: Always believed it to be normal operation. All of mine do it too. Same here... 1 hour ago, kpinnc said: My 520-H won't lift anything for 2-3 minutes after cranking, five or better when it's really cold out. 1 Share this post Link to post Share on other sites
kpinnc 15,971 #24 Posted February 9, 2022 5 minutes ago, WHX?? said: five or better when it's really cold out. Mine won't lift for several minutes in 90 degree weather! Takes a few to prime the charge pump. 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #25 Posted February 9, 2022 22 hours ago, AMC RULES said: Always believed it to be normal operation. All of mine do it too. Mine whines, and when I reach “end of travel” the pitch of the whine changes slightly . Share this post Link to post Share on other sites
