Mustang67ford 234 #1 Posted February 2, 2022 While redoing my deck, I noticed this tab welded to the middle hanger arm. It is right above the tensioner spring in the photo. I thought it was factory, but looking thru pics, I'm thinking its not. Any ideas if its factory or why the previous owner may have added it? Share this post Link to post Share on other sites
dalez 148 #2 Posted February 2, 2022 (edited) If so not factory that I know of. Edited February 2, 2022 by dalez Share this post Link to post Share on other sites
Jeff-C175 7,209 #3 Posted February 2, 2022 Not on my 42 either. I'm also not sure if mine has those 4 holes in front of the center pulley either? Share this post Link to post Share on other sites
Lee1977 7,638 #4 Posted February 2, 2022 I found the deck or one similar "05-42RY02" 1991 Its been modified to fit the tractor. It came off a machine that had the engine mounted on the back, might have been a small residential zero turn or rear engine rider. I can tell that much by the belt drawing. There was original a tab welded on right side of the deck just past front hanger, the four bolt holes was for a front mounted belt tightener. Share this post Link to post Share on other sites
oliver2-44 11,498 #5 Posted February 2, 2022 Mount it on your tractor and see what is directly above that tab Share this post Link to post Share on other sites
Jeff-C175 7,209 #6 Posted February 2, 2022 (edited) 17 hours ago, Jeff-C175 said: those 4 holes in front of the center pulley either I just confirmed that I do not have those 4 holes on mine. @Mustang67ford I've been searching Google images to see if I can find decks with those holes and I have seen one or two. Don't know what they are for. The vast majority of them do NOT have those holes. Here's a thread from 2020 posted by @tom2p that shows a 42 with those holes, so they most likely are factory, but not on all decks. Maybe Tom knows their secret special purpose? Edited February 2, 2022 by Jeff-C175 Share this post Link to post Share on other sites
Mustang67ford 234 #7 Posted February 4, 2022 On 2/2/2022 at 4:10 PM, oliver2-44 said: Mount it on your tractor and see what is directly above that tab Well, easier said than done. In the process of tractor restoration so can't do at the moment. Share this post Link to post Share on other sites
