Chaz54 102 #1 Posted January 29, 2022 (edited) Recently I upgraded the rear wheels and tires on my ‘88 520H. I replaced the std. wheels with 8.5 wide rims and the tires with Wanda 23x10.5-12 All-Terrain Golf Cart Tires. The first time I used the tractor, the hub caps fell off. I wouldn’t think that there would be a different hub cap for the wider rims, but the original hub caps just don’t fit as snug as they do on the original rims. Edited January 29, 2022 by Chaz54 Added picture. Share this post Link to post Share on other sites
Achto 32,639 #2 Posted January 29, 2022 38 minutes ago, Chaz54 said: The first time I used the tractor, the hub caps fell off Cut some small pieces of hose, slit them length wise and slip them over the clips that hold the caps on. This will help take up some extra space. You could also use car door edge molding, over the clips. 2 Share this post Link to post Share on other sites
pfrederi 21,145 #3 Posted January 29, 2022 Real men do not worry about hub caps... 2 Share this post Link to post Share on other sites
WHX?? 58,075 #4 Posted January 30, 2022 I actually removed the clips for a scratch free installation but this was a special paint job. Experiment with different diameter hoses. 1 Share this post Link to post Share on other sites
