Wheel-N-It 2,977 #277 Posted May 25, 2023 12 hours ago, squonk said: What's that Ferd? Mike, that's a 1965 Ford F-100. We named it " Ol Blue '. This trustworthy workhorse has been in the family for 26 years. It has a 240 cubic inch straight 6 engine, and a three speed transmission ( three on the tree ). I hope you like my Ferd 2 3 Share this post Link to post Share on other sites
Thegearhead0324 1,355 #278 Posted May 25, 2023 (edited) Little late but… the 1257 Edited May 25, 2023 by Thegearhead0324 Oops. 4 5 Share this post Link to post Share on other sites
WHX?? 53,703 #279 Posted May 25, 2023 (edited) 1 hour ago, Wheel-N-It said: a three speed transmission ( three on the tree Bet young wipper snappers dont have an idea what a three on a tree is. Hope to run one sometime again before I croak. Choice Van What's that Cheap Trick song? She's nice she's tight she's given me the go... Edited May 25, 2023 by WHX?? 3 2 1 Share this post Link to post Share on other sites
ebinmaine 76,474 #280 Posted May 26, 2023 1 hour ago, Wheel-N-It said: straight 6 engine Best part 1 Share this post Link to post Share on other sites
ohiofarmer 3,383 #281 Posted May 27, 2023 Did this 520H push the Oliver Super 88 Diesel backward with just a snow blade. Yeppir Doing a major organizing clean out. Of the 43x80 shop do the thundering herd gets nicely consolidated 1 Share this post Link to post Share on other sites
Wheel-N-It 2,977 #282 Posted May 27, 2023 5 minutes ago, ohiofarmer said: Did this 520H push the Oliver Super 88 Diesel backward with just a snow blade. Yeppir Doing a major organizing clean out. Of the 43x80 shop do the thundering herd gets nicely consolidated What size are the rafters in that pic? They look like 4x6 . Is that because of the snow load there where you live? 1 Share this post Link to post Share on other sites
ohiofarmer 3,383 #283 Posted May 27, 2023 7 hours ago, Wheel-N-It said: What size are the rafters in that pic? They look like 4x6 . Is that because of the snow load there where you live? 2x6x16. The main shop is about 31 feet by 80 and the width was regulated by the top chord of the truss being limited to sixteen feet. I built my own trusses back in the day to save money. The lean to was built at the same time and not an addition with thoughts that it would keep the shop area more in order. Fellas, they are never big enough, but at least I am reducing the amount of stuff laying on the floor.. . There should be room for two columns of Wheel Horses 32 feet long parked nose to tail by tomorrow. 3 Share this post Link to post Share on other sites
peter lena 9,641 #284 Posted May 27, 2023 @TJ5208 very often refer to things in plane sight , you are at the perfect stage to save and retore your paint finishes . personally like an aerosol penetrating oil , on every painted / decal finished spot . lit it sit a day , wipe off with clean soft cloth , till dry , do it again . notice how on second rub down , the finish is darker ? paint has a clean depth? at that point I use a 6" llectric palm buffer , with a cleaner wax , it just keeps getting better , also like 303 brand vinyl spray , for seat , tires . have brought back some horses that started out like yours . not difficult , if you were closer , would show you . save you paint . pete 1 Share this post Link to post Share on other sites
peter lena 9,641 #285 Posted May 27, 2023 @TJ5208 very often refer to things in plane sight , you are at the perfect stage to save and retore your paint finishes . personally like an aerosol penetrating oil , on every painted / decal finished spot . lit it sit a day , wipe off with clean soft cloth , till dry , do it again . notice how on second rub down , the finish is darker ? paint has a clean depth? at that point I use a 6" llectric palm buffer , with a cleaner wax , it just keeps getting better , also like 303 brand vinyl spray , for seat , tires . have brought back some horses that started out like yours . not difficult , if you were closer , would show you . save you paint . pete Share this post Link to post Share on other sites
peter lena 9,641 #286 Posted May 27, 2023 @TJ5208 like this , pete , also note heim joint on plow lever rod , no play , sloppyness , solid smooth / easy . pete Share this post Link to post Share on other sites
Sparky-(Admin) 24,234 #287 Posted May 28, 2023 Is this a “tight-shot”? It’s my breakfast this morning that I ate off the hood of my tractor at a show … needed a sturdy flat surface 4 2 1 Share this post Link to post Share on other sites
SylvanLakeWH 30,128 #288 Posted May 28, 2023 Yum! 1 Share this post Link to post Share on other sites
WHX?? 53,703 #289 Posted May 28, 2023 (edited) OK it ain't Tuesday so sue me... @Achto says he gets sendimental about this so who am to argue ... i know they leak Sqounky but get over it... 🤣 Edited May 28, 2023 by WHX?? 2 1 1 Share this post Link to post Share on other sites
Achto 30,435 #290 Posted May 28, 2023 (edited) 7 minutes ago, WHX?? said: @Achto says he gets sentamental about this so who am to argue if you look in the upper right hand corner, you'll see that my 953 will be running a sediment bulb too. Just like it would have had from the factory. Edited May 28, 2023 by Achto 1 2 Share this post Link to post Share on other sites
Wheel-N-It 2,977 #291 Posted May 28, 2023 3 minutes ago, WHX?? said: OK it ain't Tuesday so sue me... @Achto says he gets sendimental about this so who am to argue ... i know they leak Sqounky but get over it... 🤣 No complaints on the fuel bowl from me. I enjoy looking at it. They are not the only thing that gets a little leaky with age, but us guys have to love em' anyway. 6 Share this post Link to post Share on other sites
SylvanLakeWH 30,128 #293 Posted May 28, 2023 17 hours ago, WHX?? said: OK it ain't Tuesday so sue me... @Achto says he gets sendimental about this so who am to argue ... i know they leak Sqounky but get over it... 🤣 16 hours ago, Achto said: my 953 will be running a sediment bulb too. Sumpthing special about them bulbs... Might say they are trappingly beautiful... 1 1 1 Share this post Link to post Share on other sites
19richie66 17,770 #294 Posted May 28, 2023 They look nice when fuel of liquid. Share this post Link to post Share on other sites
WHX?? 53,703 #295 Posted May 28, 2023 40 minutes ago, 19richie66 said: They look nice when fuel of liquid. Soon grasshopper soon... 1 Share this post Link to post Share on other sites
D_Mac 9,333 #296 Posted May 28, 2023 23 hours ago, Sparky said: Is this a “tight-shot”? It’s my breakfast this morning that I ate off the hood of my tractor at a show … needed a sturdy flat surface Pancakes, sausage, and patina....mmmmmmmm 1 3 Share this post Link to post Share on other sites
SylvanLakeWH 30,128 #297 Posted May 29, 2023 5 hours ago, 19richie66 said: They look nice when full of liquid. 4 hours ago, WHX?? said: Soon grasshopper soon... Share this post Link to post Share on other sites
Sparky-(Admin) 24,234 #298 Posted June 21, 2023 B-80 8speed … 3 Share this post Link to post Share on other sites
Pullstart 68,604 #299 Posted July 9, 2024 Polished up Frank a bit today. 6 Share this post Link to post Share on other sites
ebinmaine 76,474 #300 Posted July 9, 2024 Have a closeup of some shift linkage. 2 1 1 Share this post Link to post Share on other sites
