Countdown To Christmas!
IthacaJeff
"New" 416-8 and helicoil help
IthacaJeff
WH'ers:
I just purchased this 416-8, mid 80s (Kohler K-series) with a surprisingly
solid 48" SD deck. It also has doughnut wheel weights, a rear axle quick-
attach, and good tires. It also has that fancy seat! The sheet metal has
issues that falls in line with the "What was he thinking??" reasoning.
Now the bad part. The spark plug hole was "fixed" by the previous owner
with a helicoil, but the plug rocks a bit and compression is lost through
the poorly fitting plug. I don't know if washers are needed, or the whole
helicoil needs to be re-done (if possible). This is not something I'm too
familiar with, but should I assume my local small engine repair place could
fix??
I read a prior thread about helicoils, but I'd like to get a fresh opinion,
especially since the helicoil is already in place but the plug doesn't fit.
BTW, the engine does run, surprisingly well for losing compression through
the spark plug hole.
Oh. . .$280 is what the beast cost me. Figure the mower deck, weights, and
rear attach-a-matic are worth that!
Jeff in Ithaca
hummod
IthacaJeff,
I see you made a trip to Candor. I saw that too but I
already have several projects lined up. It should be able to
to be made into a nice looking tractor again. If it were mine the
first thing i would toss is that seat. I would look for a replacement
head too instead of messing with heli-coils.
Larry (hummod)
truckin88
IthacaJeff,
Larry (hummod)
old kohler K series heads are always on ebay....just replace it.
Kelly
I have heads send me a PM, nice buy with all the stuff you didn't go wrong
