WheelHorse520H 710 #26 Posted January 28, 2022 2 hours ago, Bill D said: Make a jumper with alligator clips. Jump directly from the positive of the battery to the positive on the coil. See if your problem goes away. I had a 416 with overheated fuse holders. It ran fine for a little while, then cut out when the connections got hot. Thanks Bill, but that was Step one for me. Bypass all the safety switches, fuses, key switch, and straight up bad wiring. The problem continued. Thank you all for the suggestions, I will test this as soon as I can but we are expecting about 2 feet of snow between tonight and tomorrow. That just means I get more seat time plowing. 1 Share this post Link to post Share on other sites
Horse Newbie 7,402 #27 Posted January 28, 2022 (edited) On 1/22/2022 at 1:38 PM, WheelHorse520H said: Also worth noting the fuel filter was about half full the whole time it has been running. I can tell you this… the fuel filter is always about half full on my 1994 520H. I’ve never seen it more than 5/8ths full… Edit: Sorry… I posted this before I seen your post about possible fuel issue. Edited January 28, 2022 by Horse Newbie 1 Share this post Link to post Share on other sites
