Wheelhorse#1 1,901 #1 Posted January 21, 2022 I Have a oil leak at the governor.Does this look like a crack or do you think this may be a worn bushing ? The motor runs great otherwise.It drips at a pretty good clip once it’s warmed up.thx 1 Share this post Link to post Share on other sites
RED-Z06 2,716 #2 Posted January 21, 2022 Given that its heavy on the arm id go with bushing...do you feel much wobble in the shaft? 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,901 #3 Posted January 21, 2022 (edited) 3 minutes ago, RED-Z06 said: Given that its heavy on the arm id go with bushing...do you feel much wobble in the shaft? No wobble at all.I’ll take it apart tomorrow to get a better look. Edited January 21, 2022 by Wheelhorse#1 1 Share this post Link to post Share on other sites
squonk 45,534 #4 Posted January 21, 2022 Make sure your crankcase breather is not blocked and is on correctly. There is no seal on that gov shaft. There isn't usually a lot of oil there. Could be excess crankcase pressure forcing the oil out. 7 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,901 #5 Posted January 21, 2022 2 minutes ago, squonk said: Make sure your crankcase breather is not blocked and is on correctly. There is no seal on that gov shaft. There isn't usually a lot of oil there. Could be excess crankcase pressure forcing the oil out. Thanks I’ll take a look at that as well.Got this one at a good price.Only thing I’ve done so far is a carb cleaning / refurb and head gasket. 1 Share this post Link to post Share on other sites
RED-Z06 2,716 #6 Posted January 21, 2022 42 minutes ago, Wheelhorse#1 said: No wobble at all.I’ll take it apart tomorrow to get a better look. Hmm no wobble then the bushing shouldn't be the problem, is the oil fresh? If its contaminated with fuel it can thin out and seep 1 Share this post Link to post Share on other sites
pfrederi 19,887 #7 Posted January 22, 2022 (edited) There is no bushing in a K181 governor #25 is a spacer. #3 is the governor shaft Edited January 22, 2022 by pfrederi 2 Share this post Link to post Share on other sites
wallfish 19,320 #8 Posted January 22, 2022 I'm with Squonk. Typically it's going to be crank case pressure pushing oil out. There's no "bushing" or seal there but oil needs to be pushed out through that hole for leaking. Otherwise it just drips back down to the pan. Clogged breather or not installed properly. Or excessive blow by on the rings. Also looks to be overfilled if that much oil is pushing out. Check the level without screwing the dipstick plug into the case. 5 Share this post Link to post Share on other sites
Wheelhorse#1 1,901 #9 Posted January 22, 2022 21 hours ago, wallfish said: I'm with Squonk. Typically it's going to be crank case pressure pushing oil out. There's no "bushing" or seal there but oil needs to be pushed out through that hole for leaking. Otherwise it just drips back down to the pan. Clogged breather or not installed properly. Or excessive blow by on the rings. Also looks to be overfilled if that much oil is pushing out. Check the level without screwing the dipstick plug into the case. Right on the money, Squonk n Wallfish. Pulled the breather and found this! 1 1 Share this post Link to post Share on other sites
RED-Z06 2,716 #10 Posted January 22, 2022 Oof...yeah that's bass ackwards 2 Share this post Link to post Share on other sites
JPWH 6,542 #11 Posted January 23, 2022 I had something similar on an 854 I purchased a few years ago. Seller said it was a smoker. I asked how bad and he said not too bad it was his go to tractor. When I received the tractor it did not smoke but after running it a few minutes oil was coming from the governor just like yours. Some PO had filled the vent in the cover with Bondo and painted over it. 1 Share this post Link to post Share on other sites
RED-Z06 2,716 #12 Posted January 23, 2022 30 minutes ago, JPWH said: I had something similar on an 854 I purchased a few years ago. Seller said it was a smoker. I asked how bad and he said not too bad it was his go to tractor. When I received the tractor it did not smoke but after running it a few minutes oil was coming from the governor just like yours. Some PO had filled the vent in the cover with Bondo and painted over it. Imagine putting that much effort into creating a problem 🤣 2 Share this post Link to post Share on other sites
RED-Z06 2,716 #13 Posted January 23, 2022 Worst ive seen is a guy made an adapter and put a small carb onto an 18hp tecumseh single...said it had no power, he was definitely right, kept choking out over about 2500 rpms or if the governor reacted at all. He had the old carb, i put it back on it ran fine...no idea why he did what he did 1 Share this post Link to post Share on other sites
kpinnc 17,158 #14 Posted January 23, 2022 5 hours ago, RED-Z06 said: Oof...yeah that's bass ackwards Given the compression of a K181, I'm suprised there isn't oil coming out of the points too. 5 hours ago, Wheelhorse#1 said: Right on the money, Squonk n Wallfish. Pulled the breather and found this! Had a similar issue with a Vanguard. It blew every seal on it out at once. You got lucky! 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,901 #15 Posted January 23, 2022 7 minutes ago, kpinnc said: Given the compression of a K181, I'm suprised there isn't oil coming out of the points too. Had a similar issue with a Vanguard. It blew every seal on it out at once. You got lucky! Im guessing the PO pulled the motor for this reason.This was the only issue other than needing a good carb cleaning and just general maintenance stuff.The piston is tight and no scoring in the cylinder. .Cant complain about the 40 bucks spent for it. 1 Share this post Link to post Share on other sites
kpinnc 17,158 #16 Posted January 23, 2022 21 minutes ago, Wheelhorse#1 said: Cant complain about the 40 bucks spent for it. Heck no! Nice score! 1 Share this post Link to post Share on other sites
Horse Newbie 7,402 #17 Posted January 23, 2022 7 hours ago, Wheelhorse#1 said: Right on the money, Squonk n Wallfish. Pulled the breather and found this! Somebody enlighten a Newbie… what’s “backwards “, or wrong with it ? Share this post Link to post Share on other sites
JPWH 6,542 #18 Posted January 23, 2022 The vent plate will not allow air out. 2 Share this post Link to post Share on other sites
Horse Newbie 7,402 #19 Posted January 23, 2022 Just now, JPWH said: The vent plate will not allow air out. Where is the air supposed to go out ?… that dime sized hole ? Share this post Link to post Share on other sites
JPWH 6,542 #20 Posted January 23, 2022 Yes. That is a spring steel tab that will release pressure if you turn it around so what you see is inside. 1 Share this post Link to post Share on other sites
Horse Newbie 7,402 #21 Posted January 23, 2022 2 minutes ago, JPWH said: Yes. That is a spring steel tab that will release pressure if you turn it around so what you see is inside. Oh , so the vent plate was turned the wrong way ? So air pushes up through the dime sized hole from the side that has the orange rubber thing around the threaded sleeve/ rod(or whatever)? And when you reinstall, the dime sized hole will be towards the inside of the engine, right ? So the spring steel tab is not letting air by ? The reason I am so curious is when I was doing a little maintenance/ refreshing on my 16 hp twin Briggs on my Work Horse, I had the valve covers off, and noticed a dime sized hole in each like that. The holes were blocked by what looked and felt like Formica material(maybe it was steel) I wondered if air would pass through there so I pushed on the Formica in the holes and it felt a little springy, just not much. On the top of both the valve covers was another hole where two rubber hoses go up to the air filter box. I guess you can’t get it wrong on the Briggs twin because they will only fit one way. Sound like I am getting it now ? 1 Share this post Link to post Share on other sites
JPWH 6,542 #22 Posted January 23, 2022 I don't know about the brig's but you are correct on the Kohler. 1 Share this post Link to post Share on other sites
Horse Newbie 7,402 #23 Posted January 23, 2022 I went back to the first pic on this thread. I see now… flip the vent plate over, then the pan shaped valve cover goes on over it. 2 Share this post Link to post Share on other sites
Jeff-C175 7,207 #24 Posted January 23, 2022 35 minutes ago, Horse Newbie said: spring steel tab Technically, that's called a 'reed valve'. It allows crakcase pressure out, but won't let air back in. 3 Share this post Link to post Share on other sites
squonk 45,534 #25 Posted January 23, 2022 7 hours ago, Horse Newbie said: Somebody enlighten a Newbie… what’s “backwards “, or wrong with it ? supposed to be like this: 4 2 Share this post Link to post Share on other sites
