vrajcula 1 #1 Posted January 19, 2022 Hi, I was wondering if any one has tried to put a hydraulic or electrical lift on their wheel horse snowplow? I have a 1987 310-8. If so, how? Are you happy with it? Hydraulic or electric? Which might be best? Thanks! Vin R 1 Share this post Link to post Share on other sites
Goldnboy 1,027 #2 Posted January 19, 2022 (edited) Your going to come out this probably thinking you should buy a hydro version of the same tractor. The swap is time consuming and with the cost of parts you will probably find another tractor for the amount spent doing a swap. However it can be done. Here is a picture of my conversion on a different model series. Note I swaped in a 14Hp engine in the process too... Edited January 19, 2022 by Goldnboy 2 Share this post Link to post Share on other sites
WHX?? 51,708 #3 Posted January 20, 2022 Vin. Either way would be alot of custom work in a gear jammer. And not sure if there is a way to tie an electric into the rock shaft. Guessing you think outside the box it could be done tho. Since I am always up for buying another Golden's idea gets my vote. Plowing is much more enjoyable on a hydro. 2 Share this post Link to post Share on other sites
pfrederi 18,638 #4 Posted January 20, 2022 Get a hydro electrics are slow response ...or man up blades aren't that heavy 1 1 4 Share this post Link to post Share on other sites
Pullstart 66,647 #5 Posted January 20, 2022 if you do indeed prefer the gear jammer type, has got you covered! There were electric lift options for your model and there were 953/1054 models with gear drive AND factory hydraulics 2 Share this post Link to post Share on other sites
WHX?? 51,708 #6 Posted January 20, 2022 38 minutes ago, pfrederi said: ...or man up blades aren't that heavy You had as many shoulder cuttings as I they are a ton! 2 Share this post Link to post Share on other sites
Achto 29,381 #7 Posted January 20, 2022 NO pictures, but a friend of mine added a small winch to the front of his tractor to raise & lower the plow. Much like what is used on an ATV plow. 4 1 Share this post Link to post Share on other sites
Ed Kennell 41,802 #8 Posted January 20, 2022 2 hours ago, WHX?? said: Plowing is much more enjoyable on a hydro. Hydro Power ...the only way to go for snow machines. 3 Share this post Link to post Share on other sites
roadapples 6,983 #9 Posted January 20, 2022 25 minutes ago, Ed Kennell said: Hydro Power ...the only way to go for snow machines. And us old guys. Work smarter not harder..... 1 3 Share this post Link to post Share on other sites
SylvanLakeWH 28,343 #10 Posted January 20, 2022 2 Black Hood Eight speeds with plows here… respectfully disagree with the hydro crowd… gears work great on Michigan’s snow!!! And look at my arms!!! 1 6 Share this post Link to post Share on other sites
Ed Kennell 41,802 #11 Posted January 20, 2022 15 hours ago, Goldnboy said: Your going to come out this probably thinking you should buy a hydro version of the same tractor. The swap is time consuming and with the cost of parts you will probably find another tractor for the amount spent doing a swap. However it can be done. Here is a picture of my conversion on a different model series. Note I swaped in a 14Hp engine in the process too... I'm liking the repositioning of the blade angle rod. Did you have to bend or make a new rod when you moved it to the top of the sector or just turn the rod over. 1 Share this post Link to post Share on other sites
Goldnboy 1,027 #12 Posted January 20, 2022 3 hours ago, Ed Kennell said: I'm liking the repositioning of the blade angle rod. Did you have to bend or make a new rod when you moved it to the top of the sector or just turn the rod over. Ed since my blade is only used for dirt , I found this installation quick and easy way you use hitch pin clips for securing the rod. I just turn the rod over. However, it never occurred I may hook mine up incorrectly. Share this post Link to post Share on other sites
Ed Kennell 41,802 #13 Posted January 20, 2022 So the hole in the top plate of the sector existed? All the frames I have had, the hole is on the bottom. Share this post Link to post Share on other sites
Goldnboy 1,027 #14 Posted January 20, 2022 4 hours ago, Ed Kennell said: So the hole in the top plate of the sector existed? All the frames I have had, the hole is on the bottom. Ed I think some models have a hole on top and bottom as shown in opeators manual. 1 Share this post Link to post Share on other sites
