Mustang67ford 234 #1 Posted January 19, 2022 Picked up new rear red reflectors, not OEM. They came with double sided sticky foam backing. Do these get installed with the reflectors or just the reflector without the foam? If I install the backing, I was going to let the paper on one side so it does not stick to the tractor. Maybe overthinking, but the foam might hold water. On the other hand, the foam is a little padding to protect the paint. Maybe thinking into it too much. Share this post Link to post Share on other sites
Achto 32,511 #2 Posted January 19, 2022 1 hour ago, Mustang67ford said: Do these get installed with the reflectors or just the reflector without the foam? I install them with the 2 sided tape. The white back ground behind the reflector enhances the reflection. If you have to remove them some day a hair dryer will heat the glue up for removal. 2 Share this post Link to post Share on other sites
Mustang67ford 234 #3 Posted January 19, 2022 2 hours ago, Achto said: I install them with the 2 sided tape. The white back ground behind the reflector enhances the reflection. If you have to remove them some day a hair dryer will heat the glue up for removal. Good to know, thanks. Share this post Link to post Share on other sites
roadapples 6,987 #4 Posted January 19, 2022 Unless you want to stay all original, LED marker lights are the same size... Share this post Link to post Share on other sites
JCM 11,406 #5 Posted January 19, 2022 FYI on the taillights. In 1986 through 1989 the 414-8 did not come with taillights, reflectors were standard. I assume to keep costs down on that particular model which seem to be somewhat rare. Share this post Link to post Share on other sites
Sparky-(Admin) 26,263 #6 Posted January 19, 2022 Or run both the reflectors AND a couple LED taillights Share this post Link to post Share on other sites
Lee1977 7,756 #7 Posted January 20, 2022 I bought two red side marker from Walmarts and managed ti break the thin red covers, had the fender off leaning up against the wall it fell over and broke both of them. I order some WH covers from Wheelhorse Parts and More they fit right on, about 4 time thicker. 2 Share this post Link to post Share on other sites
