TonyBer 82 #1 Posted January 17, 2022 (edited) HI, I'm running a 79360 tall Shute (the model # sticker is damaged but fairly confident I model correct) on a C160 Automatic. This is my first year for this tractor and then I bought the snow thrower and had a knowledgeable guy install it for me properly. The first snow we had in Pittsburgh 2 or 3 weeks ago...no issues but it was only an 1" or so. Last night we got about 7" of snow and on the first row down the driveway it stopped throwing. I lifted the thrower and pulled the PTO off and then back on and up in the air, its ran freely. As soon as I get into the 7" snow (light, fluffy snow...not heavy) it boggs down and the belt stops spinning. If I clear it and restart not in the snow, its spins fine. I tried a few turns in the PTO rod with no success. Is it the belt, tensioner spring or what? The belt seems to have about 1" of play. How do I correct/fix this?....sooner rather then later as now I have a driveway full of snow LOL. Thanks! Edited January 17, 2022 by TonyBer more pics Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,451 #2 Posted January 17, 2022 Possibly the pto is slipping. Remove the trunnion from the lever above the pto and tighten by turning the trunnion 2 turns. This applies more pressure to the clutch plate when pto is applied. If you think it is still slipping do one turn at a time until the slippage is eliminated under load. 2 Share this post Link to post Share on other sites
TonyBer 82 #3 Posted January 17, 2022 7 minutes ago, gwest_ca said: Possibly the pto is slipping. Remove the trunnion from the lever above the pto and tighten by turning the trunnion 2 turns. This applies more pressure to the clutch plate when pto is applied. If you think it is still slipping do one turn at a time until the slippage is eliminated under load. Thanks...is that picture #3? As you can see the adjustment is at the end (not sure which way applies more pressure or less?). If I turn that moving the connector away from the PTO lever handle towards the snow thrower does that apply or lessen pressure? That is if it is the adjustment you are talking about? Share this post Link to post Share on other sites
squonk 47,887 #4 Posted January 17, 2022 Yup. It's tightened all the way. I bet if you pull that PTO pulley off you'll find a worn out clutch plate. 1 Share this post Link to post Share on other sites
TonyBer 82 #5 Posted January 17, 2022 This pulley? Big job? Thanks! Share this post Link to post Share on other sites
squonk 47,887 #6 Posted January 17, 2022 (edited) Easy job. Pull the belt off and pull that pin in your picture. Remove the clip holding the PTO adjustment arm and lift it off the triangle piece. Remove the 2 bolts that hold that PTO brake onSwing the Hoop / Halo looking thingy to the rear and the pulley slides right off. Then you can see the clutch plate. 4 bolts and 2 tinny plates hold the clutch plate on. Edited January 17, 2022 by squonk Share this post Link to post Share on other sites
squonk 47,887 #7 Posted January 17, 2022 The 2 nuts in this pic and the clip sticking out from under the triangle plate remove. Share this post Link to post Share on other sites
TonyBer 82 #8 Posted January 17, 2022 Awesome thank you! Share this post Link to post Share on other sites
pfrederi 21,046 #9 Posted January 17, 2022 Snow Blower belts should be in the smaller outer pulley of the PTO 2 Share this post Link to post Share on other sites
TonyBer 82 #10 Posted January 17, 2022 1 minute ago, pfrederi said: Snow Blower belts should be in the smaller outer pulley of the PTO I wondered that too...could this be the case of my problem. Can I just loosen tension on spring and move it over? Share this post Link to post Share on other sites
pfrederi 21,046 #11 Posted January 17, 2022 You say the belt stops spinning. is the PTO pulley still turning or does it stop. if it stops PTO friction plate. If the pulley still turns but the belt doesn't move wrong belt.. are you sure it is 69". Actually putting belt in outer groove will make belt slippage worse. (but that is where it should be if belt is right length... Share this post Link to post Share on other sites
Ed Kennell 46,983 #12 Posted January 17, 2022 (edited) 1 hour ago, TonyBer said: This pulley? Big job? Thanks! Looking at the joint line of the clutch plate/lining, The lining appears to be pretty thick and may be OK. The belt should be on the outer pulley to make the auger spin at the correct RPM. That is not causing the belt to slip though. The adjustment rod is maxed out and could be allowing the clutch to slip. I would run a die on there and make another inch of threads. What really jumps out at me is the lack of tension on the tensioner spring. Most of the coils are closed and not applying any tension to the belt. That spring should be shorter and streched more. Edited January 17, 2022 by Ed Kennell 2 1 Share this post Link to post Share on other sites
TonyBer 82 #13 Posted January 17, 2022 Ok...so the pulley stops turning so I'm looking at the PTO friction plate. I get in the smaller outer pulley is smaller which means it would spin the thrower faster and throw further...right? I got the belt with the used snow blower so it came with it. I'm going to order a friction plate and new belt. Any suggestions where to match a part number for a C-160 automatic for PTO friction plate? Where to reference correct belt also and order? Thanks. Share this post Link to post Share on other sites
TonyBer 82 #14 Posted January 17, 2022 3 minutes ago, Ed Kennell said: Here is another pic of the spring. Looking at the joint line of the clutch plate/lining, The lining appears to be pretty thick and may be OK. The belt should be on the outer pulley to make the auger spin at the correct RPM. That is not causing the belt to slip though. The adjustment rod is maxed out and could be allowing the clutch to slul. I would run a die on there and make another inch of threads. What really jumps out at me is the lack of tension on the tensioner spring. Most of the coils are closed and not applying any tension to the belt. That spring should be shorter and streched more. Share this post Link to post Share on other sites
pfrederi 21,046 #15 Posted January 17, 2022 Belt is 5/8 x 69" 2 Share this post Link to post Share on other sites
Ed Kennell 46,983 #16 Posted January 17, 2022 3 minutes ago, TonyBer said: Yeah, that is the picture I was refering too. That spring does not appear to be streched nearly enough to add enough tension to the belt. You have noted the PTO pulley is not turning and you must address that problem. Could be a worn lining or could be lack of tension. Do you notice any movement of the steering tower when you activate the PTO? Look for movement at the junction of the hood and tower wnhen you apply pressure to the PTO. Sometimes the towers are bent or cracked and do not transfer the proper tension to the PTO. 2 Share this post Link to post Share on other sites
TonyBer 82 #17 Posted January 17, 2022 5 minutes ago, Ed Kennell said: Yeah, that is the picture I was refering too. That spring does not appear to be streched nearly enough to add enough tension to the belt. You have noted the PTO pulley is not turning and you must address that problem. Could be a worn lining or could be lack of tension. Do you notice any movement of the steering tower when you activate the PTO? Look for movement at the junction of the hood and tower wnhen you apply pressure to the PTO. Sometimes the towers are bent or cracked and do not transfer the proper tension to the PTO. Thanks Ed, the PTO spins freely and belt until engaging 7" of snow which should be easy for this machine...then it stops after about 5 seconds. Share this post Link to post Share on other sites
oldlineman 1,800 #18 Posted January 17, 2022 also there is a plastic bushing on the PTO shaft where it goes through the tower, if it is not there could allow more play on the PTO linkage and might not allow enough tension to be put on the clutch face. Bob 1 1 Share this post Link to post Share on other sites
squonk 47,887 #19 Posted January 17, 2022 49 minutes ago, TonyBer said: . Any suggestions where to match a part number for a C-160 automatic for PTO friction plate? @76c12091520h 2 Share this post Link to post Share on other sites
peter lena 10,014 #20 Posted January 17, 2022 @TonyBer that pto cone bearing , might be an added issue , its a needle bearing , only needing a thorough wipe out, use lucas hi temp grease on it , just enough to cover the needles , another thing noticed was the spring tensioned pulley frame , no grease or lubricants seen in those steel on steel holes , if its lubricated it works better . also lubricate the related pto, trunnion , joint. also lubricate the base of that chute to blower frame , super lube teflon spray or related snow spray , there and inside chute. look and detail every intended function , when they are all working with simple ease , its a neat set up , pete 1 Share this post Link to post Share on other sites
TonyBer 82 #21 Posted January 17, 2022 15 minutes ago, peter lena said: @TonyBer that pto cone bearing , might be an added issue , its a needle bearing , only needing a thorough wipe out, use lucas hi temp grease on it , just enough to cover the needles , another thing noticed was the spring tensioned pulley frame , no grease or lubricants seen in those steel on steel holes , if its lubricated it works better . also lubricate the related pto, trunnion , joint. also lubricate the base of that chute to blower frame , super lube teflon spray or related snow spray , there and inside chute. look and detail every intended function , when they are all working with simple ease , its a neat set up , pete Will do, is the bearing visible when I get the clutch plate out? Is there a guide to show where to lubricate all? I'll pickup some teflon spray and get some Lucas hi temp grease. Thanks. 1 Share this post Link to post Share on other sites
peter lena 10,014 #22 Posted January 17, 2022 @TonyBer when i got my 36x42 single stage blower , it was a mess , everything on it worked like dragging a rock , no lubrication , solid rust , noisy bearings. the bearing is INSIDE the pto pulley nose cone area , a snap ring removes , the connection link ' found this link ,https://wheelhorsestables.com/forum/engine-tutorials/190-pto-clutch-disc-diy great pictures , self explanatory , get back to you pete Share this post Link to post Share on other sites
peter lena 10,014 #23 Posted January 17, 2022 @TonyBer when i got my 36x42 single stage blower , it was a mess , everything on it worked like dragging a rock , no lubrication , solid rust , noisy bearings. the bearing is INSIDE the pto pulley nose cone area , a snap ring removes , the connection link ' found this link ,https://wheelhorsestables.com/forum/engine-tutorials/190-pto-clutch-disc-diy great pictures , self explanatory , get back to you pete Share this post Link to post Share on other sites
squonk 47,887 #24 Posted January 17, 2022 The adjustment bottomed out tells me the PO had issues with the clutch before. 3 Share this post Link to post Share on other sites
peter lena 10,014 #25 Posted January 17, 2022 @TonyBer LUCAS , X-TRA HEAVY DUTY GREASE , WALLMART . $ 7 , hi temp , 560 deg drop point , anti sling rated , polyurea rated , bombproof stuff , that suber lube teflon spray is perfect on that blower chute base and inside chute for slick release, also it on your snow blade , don,t get me started , pete 1 Share this post Link to post Share on other sites
