WH854
Fender Pan From Plastic To Metal
WH854
I am going to put a metal fender on my C-105, here is the start!
Under Coat
Bottem
Bottem Painted
Have to wait 48 Hours to paint the Top.
Got this on ebay for $10.00
Think it will work?
Chas :thumbs2:
bo dawg
I believe its gona be a dandy looking one!
:thumbs2:
TJ
Looks good. :thumbs2:
Duff
You got yourself a good deal, Chas, and the redo is coming along really nice!
Duff :thumbs2:
d180man
Hi look good i need to do that too! :thumbs2: to our c-161 :thumbs: :ychain:
WH854
Update on fender pan!
Not to bad for an old man. (None painter)
Chas :thumbs2:
WH854
Update put fender pan on tractor, plus new seat new bolts new gas guage and cap.Here is a couple of pictures!
Chas :thumbs2:
JimD
it looks real good chas :thumbs2:
WH854
I have some more picturesof my C-105
New Decal on back
Got the engine back about a week a go new gov.gear,Exh valve,new points,H10C plug,block bored to .020 over Crank ground with Rod insert.installed engine in tractor,tried starting it would not fire.So I disconncted fuel pump an rigged up a gravity flow gas tank,Hit key again she fired right up, bad fuel pump.So I bought a new replacement fuel pump mad out of hard plastic,it is working fine so far,oh yeah a new starter,new fuel line.I have been running up an down our road. The TWP Road Dept.has it closed down temp.
If this is in the wrong setion you Mods can move it. :thumbs2:
Chas :thumbs: :ychain:
WH854
Here is That gravity feed I was talking about.
That is the muffler in front.
Chas.
TT
Glad to see you got the Horse back up on it's feet again, Chas!
Who did the connecting rod bearing insert for you?
WH854
Thanks TT Itook it to Mulligan's Small Engine Repair 3136 William Flynn HWY.
Slippery Rock,Pa.16057 phone or Fax(724)794-5723.But he send them out to get block bored, crank done, got to be in the area $35.00 For Bore job, $125.00 for crank and insert job. :thumbs2:
Chas. :thumbs:
WH854
More pictures of my C-105
These are the patch job on the deck.
These are after I got deck back on tractor.
That is my helper in this one
I got this all installed today.Tried it out for about an hour,the mower worked perfect
gotta give myself some attaboys. :thumbs2:
Chas. :thumbs:
Rod(NASNUT)
Nice job. Looks great :thumbs2:
Save Old Iron
Chas,
what type of material did you use to patch the mower deck ?
WH854
I don,t weld! But i took it to a friend of mime in the body shop business. he told me he used a piece of metal from, metal beams they use in buildings It was galvanised I believe. he used one of those wire welders.
Chas :thumbs2:
HorseFixer
Looks good Chas :thumbs2: Duke approved :thumbs:
WH854
A great Big :thumbs2: to all you guys for the compliments. I did not think I would ever get this far with it.I guess I am a stubborn old cuss, not to give up on her.She rewarded me today, I mowed about an acre of grass (weeds)included.Grand Old Tractor. Chas :thumbs:
WH854
Guess I'll drag this out of the archives too :thumbs:
Chas
Butch
Sweet!
oneroadkingman
wow I must say that is a nice looking tractor u got there. I hope I can do half is good of a job with mine as you did..
WH854
Thank Ya Mate :thumbs:
Chas
608KEB
Looks nice.
