JD guy 1 #1 Posted January 12, 2022 I lost battery / volt meter charge on 520H. Found partially heat scorched red charge wire connector at 9 pin connector. Cleaned up this terminal of 9 pin connector and charge has come back to 14 volts. When charge wasn't working, the tach came back to life but left when 9 pin connector cleaned up. Also cleaned 3 terminals of RR. The double jump terminal of the RR (black from AC and grey to tach) are toward front of tractor / the center terminal on RR is red charge wire / the rear terminal is black from AC. Tach wont work after terminals cleaned and hasn't worked since I got unit several hours ago. I read and saw post photo with jump wires on rear terminal of RR (toward rear of tractor). Will it hurt anything electrical to switch the front and rear connections on the RR - moving the jump connection (black wire and grey wire) to terminal toward rear of tractor? Tach didn't work since I got unit from a friend who had it from new and unit had RR connections with the jump (double) connection toward front of tractor (grey tach wire and black AC wire there) - red charge wire on center post - single black wire on rear most post). Share this post Link to post Share on other sites
lynnmor 8,258 #2 Posted January 12, 2022 The factory position was the rear terminal for the tach connection. I never thought it made any difference since it is just AC current to the two outside terminals, but swap them and retry. Share this post Link to post Share on other sites
Ed Kennell 43,785 #3 Posted January 12, 2022 Either AC terminal should work. Did you check and clean the terminal at the tach ? Tach ground? Share this post Link to post Share on other sites
JD guy 1 #4 Posted January 13, 2022 Thanks for input on tach- I switched jump connector with grey tach wire to rear post on RR- tach came back to life!! 1 Share this post Link to post Share on other sites
