truckin88 104 #1 Posted June 23, 2009 So I took my side tins off, and inspected my drive belt, and it is in really good shape. The PTO belt was just replaced by me, well I posted about an oil leak on my newly aquired 520-H, I thought I fixed it cleaning the crankcase breather, all it did was slow the leak down. I now found it is the PTO gasket. Where do I get a new one? Will I need special tools to replace, any other gaskets replaced while I am in there, I have never done this job so all info is appreciated. I guess at least I know it does not burn oil now! HELP!!!!!! PLEASE!!! Share this post Link to post Share on other sites
truckin88 104 #2 Posted June 24, 2009 anyone? could I just use RTV?? I doubt anyone has one in stock. Share this post Link to post Share on other sites
catman81056 3 #3 Posted June 24, 2009 PTO gasket? All my tractors are older models, but I've never seen a PTO that contained oil. Is the crank seal leaking or maybe the side plate gasket? Share this post Link to post Share on other sites
truckin88 104 #4 Posted June 24, 2009 It is the gasket between the block ande the round plate directly behind the PTO pulley/ drive belt pulley. Sorry for not know the correct terminology here. Hope this helps. There is a gasket as I can see about 3 inches that are sticking out broken off. This is an Onan 20HP Twin Share this post Link to post Share on other sites
truckin88 104 #5 Posted June 24, 2009 the round gasket with bolt holes seen here: http://cgi.ebay.com/NEW-ONAN-BF-B43-48-P-2...alenotsupported Thats what I am talking about, who would carry one locally? what is it called. How hard is it to replace, any help is appreciated.!!! Share this post Link to post Share on other sites
Jim_M 179 #6 Posted June 24, 2009 The plate you're talking about is the crankshaft bearing retainer plate. That kit you linked to also includes the crankshaft seal. It's a good idea to replace the seal while you've got the retainer plate off, if you don't there's a good chance it will leak when you put it back together. It's not a hard job. Share this post Link to post Share on other sites
truckin88 104 #7 Posted June 24, 2009 any speacial tools? where does the crankshaft seal go? Is it pretty basic once I am in there? I am guess the crankshat seal is one of the small round ones. Any advice??? Thank you. Should I prelube the gaskets??? I ordered the kit. Share this post Link to post Share on other sites
Jim_M 179 #8 Posted June 24, 2009 Once you take the pto off take a look at it, it will explain itself. Use motor oil or light grease on the seal. You'll need a torque wrench. Don't overtorque the retainer plate, remember you're working with aluminum.... Share this post Link to post Share on other sites
truckin88 104 #9 Posted June 24, 2009 Once you take the pto off take a look at it, it will explain itself. Use motor oil or light grease on the seal. You'll need a torque wrench. Don't overtorque the retainer plate, remember you're working with aluminum.... Thank you very much, will I need bearing grease for anything? Does this kit have all the seats I need for replacing that bearing plate seal on the 520-H It is a slow leak, but bothers me that it is leaking. Is there anything else I should change out while I am in there. I figure I might as well get a drive belt while I am in there. This is becoming more work then I expected, but when done it will be one heck of a machine. Share this post Link to post Share on other sites
Bow_Extreme 578 #10 Posted June 24, 2009 Sounds like you did get the answers you were looking for so I will disregard the PM you sent me. Jim M is correct. It's pretty straight forward to replace the crank seal and plate gasket. Good Luck!! Share this post Link to post Share on other sites
truckin88 104 #11 Posted June 24, 2009 thanks bow and Jim M for all the advice, I am hoping I am up to the task, but not sure, plus not sure how time consuming it is, with work and all. The kit is ordered we shall see. Nervous about this, I am decent mechanically the finess stuff is not my strong point, anyone wanna trade a 400 series 8 speed for the 520, I will include the gaskets ha Are there any special tools required, any other parts I should replace? Thanks, -Will Share this post Link to post Share on other sites
catman81056 3 #12 Posted June 25, 2009 Here's a tip to prevent oil seepage; use brake parts cleaner to clean all gasket surfaces, get every bit of oil residue off the surfaces. If you plan on using RTV sealer, dab just a small amount on the gasket surface and then use you finger to spread it around. You just want a thin film of sealer, not enough to squeez out when tightened up. Just my .02, works real well for me. Share this post Link to post Share on other sites
truckin88 104 #13 Posted June 25, 2009 Here's a tip to prevent oil seepage; use brake parts cleaner to clean all gasket surfaces, get every bit of oil residue off the surfaces. If you plan on using RTV sealer, dab just a small amount on the gasket surface and then use you finger to spread it around. You just want a thin film of sealer, not enough to squeez out when tightened up. Just my .02, works real well for me. Catman, should I use RTV, instead of the gasket set I bought??? Should I use both?? Thanks. Share this post Link to post Share on other sites
Jim_M 179 #14 Posted June 25, 2009 You can use both, just don't get carried away with the RTV. Share this post Link to post Share on other sites
catman81056 3 #15 Posted June 25, 2009 What Jim said Remember, a "very thin" film of sealer. Share this post Link to post Share on other sites
truckin88 104 #16 Posted June 25, 2009 tear down has begun, since I have today off, 2 sets of seals are on order, this way incase I rip one. Share this post Link to post Share on other sites
truckin88 104 #17 Posted June 25, 2009 Ok I am doing a bunch of stuff at once. Anyways, is there an easy way to get the drive belt out. I pulled up on the tranny disengage, but there is still tension....please help!!! Share this post Link to post Share on other sites
