DeepH2O 66 #1 Posted January 6, 2022 Do you guys know if there’s a difference in size of cylinder head on 10 & 12 HP Kohlers? I found one on EBay but it’s labeled part number KH10261 and advertises it’s for a 310-8. But, part number for 310-8 is KH10260 (10HP). I’m assuming since there’s different part numbers they’re different sizes. Share this post Link to post Share on other sites
Maxwell-8 4,371 #2 Posted January 6, 2022 The bore is different, so I would assume they are different. Share this post Link to post Share on other sites
Achto 32,795 #3 Posted January 6, 2022 6 hours ago, DeepH2O said: Do you guys know if there’s a difference in size of cylinder head on 10 & 12 HP Kohlers? K241 (10hp), K301 (12hp), and K321 (14hp) heads are interchangeable. 2 1 Share this post Link to post Share on other sites
oliver2-44 11,758 #4 Posted January 6, 2022 The part number comes up as for a Magnum k series which is the same and a good thing. Somewhere along the K series production one of the valves was changed to a larger head. I'm not sure if the head had to be modified or not. But this appearing to be a Magnum head would mean it would fit the larger valve if there was actually any change. 1 Share this post Link to post Share on other sites
kpinnc 18,976 #5 Posted January 8, 2022 They also moved the location of the spark plug a couple times. Very little effect on the performance, but might not match the original sheetmetal... Share this post Link to post Share on other sites
DeepH2O 66 #6 Posted January 8, 2022 10 hours ago, kpinnc said: They also moved the location of the spark plug a couple times. Very little effect on the performance, but might not match the original sheetmetal... Ahhhhh, thanks for the heads up!! Share this post Link to post Share on other sites
