chev0545 237 #1 Posted January 3, 2022 when first started with choke get put put & blue smoke runs rough for 10 sec.is there an adjustment? thanks Share this post Link to post Share on other sites
RED-Z06 2,700 #2 Posted January 3, 2022 6 minutes ago, chev0545 said: when first started with choke get put put & blue smoke runs rough for 10 sec.is there an adjustment? thanks The carb on these is very large for the engine, i normally choke when cold and as it cranks over shove the choke in...or you'll hose the plugs down with fuel...you might have a failing plug also.. 1 Share this post Link to post Share on other sites
Maxwell-8 4,370 #3 Posted January 3, 2022 11 hours ago, chev0545 said: blue smoke That is most of the time Oil, maybe you have some oil passing by the valve guides? How many hours does the machine have? You notice any lose in oil? 1 Share this post Link to post Share on other sites
Handy Don 15,637 #4 Posted January 3, 2022 When choked, the engine is intake causes a lower pressure in the combustion chamber so it may be pulling oil off the cylinder walls around the rings and burning it. 1 Share this post Link to post Share on other sites
cleat 8,385 #5 Posted January 3, 2022 With small engines, I don't worry about a puff of blue when starting with the choke on. Even some brand new engines seem to do this a bit. Now, if you are fogging mosquito's with a heavy smoke then you may have an issue. 3 Share this post Link to post Share on other sites
