Elkskin's mower junkyard 1,117 #1 Posted January 1, 2022 Decided it was time to get wagon out and fix it. has i was disassembling i thought of ways to fix the front axle because i knew it was messed up. but before that i had to look at the long side panels which the one needs some repairs. now after i got the side panels off i flipped it over and looked at axle. i decided i am going to cut out the square tubing someone tried fixing it with before and i will bolt in some thick angle iron. that should keep it from breaking. i also have another idea for the bolts to hold sides to keep it from crushing the metal because i am not going to use wing nuts on the sides. i will put some sort of spacers in the holes. pictures may be out of order. i do not know model number of the wagon. its missing the decal for the serial and model. i do know i narrowed it down by the side panel decals but cant really remember lol 6 3 1 Share this post Link to post Share on other sites
ebinmaine 80,950 #2 Posted January 1, 2022 Right crusty bugger ain't it? Looking forward to seeing the improvements. 1 Share this post Link to post Share on other sites
AMC RULES 37,260 #3 Posted January 1, 2022 Suggesting that you may want to try putting that wagon back to it's original form as much as possible as there is some value in them as a W-H collectible. 1 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #4 Posted January 1, 2022 56 minutes ago, AMC RULES said: Suggesting that you may want to try putting that wagon back to it's original form as much as possible as there is some value in them as a W-H collectible. i do know that they are worth good money. i have no way of putting the square holes in the side panel once i fix the broken out area. the front axle situation is more along the lines of bracing and improvement. one original rim is missing i think i found a suitable replacement. Share this post Link to post Share on other sites
ebinmaine 80,950 #5 Posted January 1, 2022 11 minutes ago, Elkskin's mower junkyard said: way of putting the square holes I've used a regular drill bit to get the round size right then a triangle shaped file to get the corners squared. A bit of time occupied and works well enough. 4 1 Share this post Link to post Share on other sites
WHGuy413 2,859 #6 Posted January 1, 2022 29 minutes ago, Elkskin's mower junkyard said: one original rim is missing i think i found a suitable replacement. What did you find to use? I have a 4 wheeled wagon also that someone repainted and put wheelbarrow tires and rims on it. I want to start hunting for the correct ones. Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #7 Posted January 1, 2022 2 hours ago, WHGuy413 said: What did you find to use? I have a 4 wheeled wagon also that someone repainted and put wheelbarrow tires and rims on it. I want to start hunting for the correct ones. a rim from a 753 is the closest thing i have 1 Share this post Link to post Share on other sites
WHGuy413 2,859 #8 Posted January 1, 2022 19 minutes ago, Elkskin's mower junkyard said: a rim from a 753 is the closest thing i have That was my idea also was early 60’s front rims. Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #9 Posted January 2, 2022 Got some more done. i thought i would update on some things. so i cut out the square tubing. you can see its way too thin. then i looked at angle iron and didnt like it. so i found a thicker flat bar from a seat support on a simplicity rear engine rider. i cut a piece out drilled the holes and then i cut out the bad section. i found a piece of plate steel i had cut out a piece and welded it in. then i bolted the flat piece on the top drilled hole then put the flat piece back where it goes for strength. now i have to do the other side 4 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #10 Posted January 3, 2022 ok guys a bit of a update. jb weld was taking too long to do it. so even though i dont like using bondo to fix pitted metal i went ahead and bought some anyway. i worked at it all afternoon and my hand and arm said are you done yet lol. so i got it alot smoother than it was. i did sand it down alot more than what the unprimered photos show so dont hopefully it wont crack lol. so i am debating on the bedliner still. it will hide some of the imperfections and add durability. for local shows i might put my 1964 24 inch tiller in the wagon so would be nice to make it where it wont get damaged easily. 4 1 Share this post Link to post Share on other sites
rustyoldjunk 127 #11 Posted January 3, 2022 Looks good Tyler. See I'm still around here..well once in a while and very 🤫 quietly. 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #12 Posted January 3, 2022 Just now, rustyoldjunk said: Looks good Tyler. See I'm still around here..well once in a while and very 🤫 quietly. 1 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #13 Posted January 4, 2022 Got bed liner laid down. It's not perfect but hey if it's too perfect I won't want to use it lol 3 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,703 #14 Posted January 4, 2022 Looks great! Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #15 Posted January 6, 2022 I done the bottom of floor last night. Tonight I painted the top over the bed liner. Yeah I know bottom may get a couple dings being so fresh but that's not seen every day 3 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #16 Posted January 9, 2022 Not much updates I got 2 long sides done and the frame rails and brackets. They are now in cold storage until I get rest done 4 2 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #17 Posted January 12, 2022 Ran into a issue today. One of the original 3 rims is heavily pitted on inside. So I am going to work on that one later this year. Instead I had a pair of miscellaneous rims sitting in shed that I will use temporarily. 6 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #18 Posted January 13, 2022 Assembly is underway. Now is cross breeding tires from John deere snowblowers illegal 🤣. 2 2 1 1 Share this post Link to post Share on other sites
ebinmaine 80,950 #19 Posted January 13, 2022 6 hours ago, Elkskin's mower junkyard said: is cross breeding tires from John deere snowblowers illegal Kinda yes but correcting paint colors and cleaning makes it only a minor infraction. Share this post Link to post Share on other sites
AMC RULES 37,260 #20 Posted January 13, 2022 Thing looks great! Just keep it going. 1 Share this post Link to post Share on other sites
rjg854 13,405 #21 Posted January 13, 2022 Looking forward to seeing it finished Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #22 Posted January 14, 2022 It's together. I will wait a couple months for decals. But hey it looks a heck of a lot better. I will get better pictures Saturday hopefully. 3 7 Share this post Link to post Share on other sites
ebinmaine 80,950 #23 Posted January 14, 2022 Boy ain't that purrttyy. Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #25 Posted January 14, 2022 1 hour ago, AMC RULES said: Yup those are the ones. 1 Share this post Link to post Share on other sites
