Joe 77 B100 84 #1 Posted December 27, 2021 A mechanic friend of mine suggested I replace the points on my 77 b100 with this. https://www.amazon.com/dp/B007BI6FW6?ref=ppx_pop_mob_ap_share Any experience or thoughts? Share this post Link to post Share on other sites
oliver2-44 11,326 #2 Posted December 27, 2021 You cannot use them with an engine that has a charghing system. This thread talks about them. 3 Share this post Link to post Share on other sites
Achto 31,310 #3 Posted December 27, 2021 4 minutes ago, ecojoe69 said: Any experience or thoughts? You'll get mixed reviews from me. I've had luck and no luck with them. 1 Share this post Link to post Share on other sites
ebinmaine 77,821 #4 Posted December 27, 2021 I have a nova kit in a Briggs. Definitely happy with it but I wouldn't bother to put one in a Kohler even if I could. I don't believe they're compatible but there's no real need. Kohler points last decades. Just keep them clean and set right. I've read about Kirk's Transdenser condenser replacement. That might be a worthwhile thought. 3 Share this post Link to post Share on other sites
RED-Z06 2,718 #5 Posted December 27, 2021 Ive used Nova2 on Stihl 031av saws because ignition parts on early points models don't exist... But...my Kohlers, i really never have to mess with points. If the condenser is good the points will go many years between maintenance 3 Share this post Link to post Share on other sites
953 nut 64,649 #6 Posted December 27, 2021 11 hours ago, ecojoe69 said: A mechanic friend of mine suggested I replace the points on my 77 b100 with this. https://www.amazon.com/dp/B007BI6FW6?ref=ppx_pop_mob_ap_share Any experience or thoughts? Copied this directly from the Amazon listing, gotta read the fine print before throwing your money at a problem. Product Description NEW ELECTRONIC TRANSISTORIZED IGNITION MODULE ( NOVA II) Used By Kawasaki and Other OEM's Easy to install compact design For most 2 and 4-cycle engine applications, such as brush cutters, chain saws, trimmers, garden tillers, snowthrowers and lawnmowers. Easy start fires well at low rpm’s, NOT for use in battery ignition applications. Replaces points and condenser. Single cylinder. Universal application. Does NOT work with most Stihl trimmers and chain saws. 3 1 Share this post Link to post Share on other sites
ebinmaine 77,821 #7 Posted December 27, 2021 11 hours ago, ecojoe69 said: thoughts 10 minutes ago, 953 nut said: throwing your money at a problem Good post Richard. @ecojoe69 I hadn't thought to ask WHY you wanted to use the Nova ignition. No start? Rough running? Share this post Link to post Share on other sites
Joe 77 B100 84 #8 Posted December 27, 2021 I was asking my car mechanic friend about cleaning and setting points and he said: "I don't mess with them- I just convert to them to..." So, I thought I would ask you folks. I opened up the points housing the other day and it seems to me the points system in there is a replacement and not the original. I wanted to clean and check it. Being in there made me think that I should ask you folks since I have your experience to guide me. I just got a new battery and with the holidays behind me, I should be able to go through all of the checks with the voltage meter you've all told me about and all of the YouTube videos showed me to find the problem. As a reminder, the machine will making a whirring sound (which I think is the starter trying to start the engine, but I got no turn over so far when I bypass the ignition and arc the solenoid posts. Question: The little rod that pushes the points doesn't seem to move much at all when I turn the pulleys (I am sure that has a proper name) to move the rod to the "all the way out" position. I assumed it would move quite a bit more. How much should it move? And, it pulls all the way out. Should that be the case? Share this post Link to post Share on other sites
ebinmaine 77,821 #9 Posted December 27, 2021 1 hour ago, ecojoe69 said: , the machine will making a whirring sound (which I think is the starter trying to start the engine, but I got no turn over so far when I bypass the ignition and arc the solenoid posts Likely the starter needs a clean out. There's a thread for that with a great explanation. Very easy to do. 1 hour ago, ecojoe69 said: Question: The little rod that pushes the points doesn't seem to move much at all when I turn the pulleys (I am sure that has a proper name) to move the rod to the "all the way out" position. I assumed it would move quite a bit more. How much should it move? And, it pulls all the way out. Should that be the case? Seems to me it won't need to move much though I don't know the actual spec. I believe that rod is straight so it makes sense it could pull straight out. 1 hour ago, ecojoe69 said: was asking my car mechanic friend about cleaning and setting points and he said: "I don't mess with them- I just convert to them to..." So, I thought I would ask you folks No offense intended against your mechanic friend. He's obviously not accustomed to working on older Kohler engines. It's good you asked here before tossing money. 1 Share this post Link to post Share on other sites
RED-Z06 2,718 #10 Posted December 27, 2021 He probably converts his points ignition vehicles to a "Pertronix Ignitor"... 1 Share this post Link to post Share on other sites
Joe 77 B100 84 #11 Posted December 27, 2021 37 minutes ago, ebinmaine said: Likely the starter needs a clean out. There's a thread for that with a great explanation. Very easy to do. Could you send me a link to the right one? I will certainly try that out. Share this post Link to post Share on other sites
WHX?? 55,705 #12 Posted December 27, 2021 I've got a nova just cause it was cheap and someday going to try it on a Clinton B1290. Points are under the flywheel and a pain to get at if they oxidize. As was said tho cannot have charge magnets. 1 Share this post Link to post Share on other sites
ebinmaine 77,821 #13 Posted December 27, 2021 16 minutes ago, ecojoe69 said: Could you send me a link to the right one? I will certainly try that out. 1 Share this post Link to post Share on other sites
Achto 31,310 #14 Posted December 27, 2021 3 hours ago, ecojoe69 said: assumed it would move quite a bit more. How much should it move? And, it pulls all the way out. Should that be the case? It only has to move enough to open the points .020" so you will not see much movement. The points spring tension is the only thing that holds the rod in, it will pull right out if the points are removed. 1 Share this post Link to post Share on other sites
