clueless 3,345 #1 Posted December 22, 2021 (edited) Will a Kohler M8 8hp fit on a 702, looks to be the same engine as the K161 size except the carb and air filter stick out more. The pto shaft is the correct size. Edited December 23, 2021 by clueless Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #2 Posted December 23, 2021 yes a magnum 8 will fit. use the k161 airbox. i also used the m8 relocated throttle and choke controls. 1 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #3 Posted December 23, 2021 1 hour ago, clueless said: Will a Kohler M8 8hp fit on a 702, looks to be the same engine as the K161 size except the carb and air filter stick out more. The pto shaft is the correct size. i forgot to add in previous post leave breather tube vent into atmosphere like the k series did. Share this post Link to post Share on other sites
clueless 3,345 #4 Posted December 23, 2021 12 hours ago, Elkskin's mower junkyard said: i forgot to add in previous post leave breather tube vent into atmosphere like the k series did. Pictures of how you ran the throttle and choke cables would be appreciated. Also mine is an electric start. Share this post Link to post Share on other sites
