Craig-906 28 #1 Posted December 19, 2021 Has anyone used trufuel in your tank before storing your tractor for the winter? Share this post Link to post Share on other sites
squonk 44,891 #2 Posted December 19, 2021 That's what I use for storing the winter equipment all summer and the show tractors during the winter. 2 Share this post Link to post Share on other sites
Brockport Bill 2,125 #3 Posted December 19, 2021 how do you use it - do you run it thru for a few minutes or what? Share this post Link to post Share on other sites
rjg854 12,637 #4 Posted December 19, 2021 I would say that's the best idea that way you can get the true fuel into your bowl on your carburetor 3 Share this post Link to post Share on other sites
Craig-906 28 #5 Posted December 19, 2021 29 minutes ago, Brockport Bill said: how do you use it - do you run it thru for a few minutes or what? Pour in tank and run for a bit to get it in the bowl. be careful not to use the mixture one. 1 1 Share this post Link to post Share on other sites
Bill D 2,445 #6 Posted December 19, 2021 2 minutes ago, Craig-906 said: Pour in tank and run for a bit to get it in the bowl. be careful not to use the mixture one. I've used the 50:1 mix for storage without issue. Any fuel left in the bowl after you run it dry will evaporate and the left over oil will coat the carb components and preserve them. 1 Share this post Link to post Share on other sites
ri702bill 10,639 #7 Posted December 19, 2021 Craig: Yes - pricey, but it works. IF you are fortunate to have a NON ethanol fuel supplier near you - use that.- the orange or blue stores get about $20 for a "short" gallon here - non ethanol fuel is NOT that readily available here in the southern NE area. Short version - yes use it to run a tank or so before winter - FILL metal tanks with it for over the winter - NO issues starting in the spring ... 1 Share this post Link to post Share on other sites
Brockport Bill 2,125 #8 Posted December 19, 2021 I have kept my 312-8 (with Kohler) indoors for winter all its 32 yrs - but used for plowing so it is periodically active for winter snow. However, I now have a few other horses that will be outdoors in unheated shed ( Hudson Valley, NY temps ) . Some will be used, others stored and not run till spring - is there such a term as "winterizing" tractors other than the typical engine routine of running gas dry as discussed here - or removing battery and trickle charging? What else might be "tips" for a WH that may not be used for winter months, or perhaps one that may be used occasionally? I have only had to start warm tractor from heated garage. I see comments about tractors outdoors in winter that "start right up" when temps in the single digits? Is that to be expected? Are there any other operational issues other than oil viscosity? thanks 1 Share this post Link to post Share on other sites
rjg854 12,637 #9 Posted December 19, 2021 All my tractors are kept in an unheated shed and I have no problem starting them, even when the temps get down near zero. 1 Share this post Link to post Share on other sites
Brockport Bill 2,125 #10 Posted December 19, 2021 11 minutes ago, rjg854 said: All my tractors are kept in an unheated shed and I have no problem starting them, even when the temps get down near zero. brrr - Finger lakes even colder than here - I did college at Brockport and its the lake wind as well as snow there !!!!!!!!!!! 1 Share this post Link to post Share on other sites
rjg854 12,637 #11 Posted December 19, 2021 This year has certainly been a good year for wind 1 Share this post Link to post Share on other sites
Craig-906 28 #12 Posted December 19, 2021 2 hours ago, ri702bill said: Craig: IF you are fortunate to have a NON ethanol fuel supplier near you - use that. I do. Admittedly I completely forgot about this and was reminded by @phil bowling that we have this in the area, still. 1 Share this post Link to post Share on other sites
ri702bill 10,639 #13 Posted December 19, 2021 You are fortunate - I live in "dry" county .... 1 2 Share this post Link to post Share on other sites
jtrosp1980 89 #14 Posted December 20, 2021 I put seafoam In and fill the tank never want to run them out bad on fuel pumps 2 Share this post Link to post Share on other sites
Brockport Bill 2,125 #15 Posted December 20, 2021 5 hours ago, jtrosp1980 said: I put seafoam In and fill the tank never want to run them out bad on fuel pumps never knew that about the fuel pump - what does it do to them? Share this post Link to post Share on other sites
jtrosp1980 89 #16 Posted December 20, 2021 Bye running them dry you put air in the system Share this post Link to post Share on other sites
