Sodaking27 1,279 #1 Posted December 17, 2021 Have the chance to pickup a set of MTD front wheel weights for a really good price. I know the bolt pattern does not match the WheelHorse holes in the rims. 4.5” vs 5”. My question is can I enlarge the holes so they will work with out having to drill new holes in the rims? Thanks.. Share this post Link to post Share on other sites
slim67 2,825 #2 Posted December 18, 2021 29 minutes ago, Sodaking27 said: Have the chance to pickup a set of MTD front wheel weights for a really good price. I know the bolt pattern does not match the WheelHorse holes in the rims. 4.5” vs 5”. My question is can I enlarge the holes so they will work with out having to drill new holes in the rims? Thanks.. I just drilled new holes and they worked fine. I lined up the holes with a center punch. Share this post Link to post Share on other sites
Sodaking27 1,279 #3 Posted December 18, 2021 Slim, Drilled new holes in the weights or the rims? I was hoping to enlarge the holes in the weights. Share this post Link to post Share on other sites
slim67 2,825 #4 Posted December 18, 2021 8 minutes ago, Sodaking27 said: Slim, Drilled new holes in the weights or the rims? I was hoping to enlarge the holes in the weights. Sorry, I drilled the wheels. Share this post Link to post Share on other sites
slim67 2,825 #5 Posted December 18, 2021 I set the weights where I wanted the holes to go. I marked the end of a punch that was the same diameter of the bolts holes with a sharpie so it would leave a mark. Center punched the dots and drilled out with a 3/8 drill bit. Worked like a charm. 2 Share this post Link to post Share on other sites
Sodaking27 1,279 #6 Posted December 18, 2021 So the existing holes are no where close to matching up? I was thinking there is only a 1/2” difference and I could enlarge the existing holes to match. If that can’t be done, I will do like you did. Share this post Link to post Share on other sites
slim67 2,825 #7 Posted December 18, 2021 1 hour ago, Sodaking27 said: So the existing holes are no where close to matching up? I was thinking there is only a 1/2” difference and I could enlarge the existing holes to match. If that can’t be done, I will do like you did. No they aren’t unfortunately. Share this post Link to post Share on other sites
