Boone 1 #1 Posted December 13, 2021 Blade year by decal ?? Share this post Link to post Share on other sites
8ntruck 9,340 #2 Posted December 13, 2021 to the forum. A picture of the model and serial number plate (if still there) would be a better clue to point you to the parts and manuals that will help you. If you could post a picture of the whole machine, we can tell you where to find the model and serial number plate. 1 Share this post Link to post Share on other sites
8ntruck 9,340 #7 Posted December 13, 2021 OK, it is a plow/dozer blade. The model identification should be in one of the upper corners on the back side of the blade. Judging by the amount of pitina, I'll guess that it is gone. These blades are identified by the width of the blade and the length of the frame that connects it to the tractor. Working from memory, they came in widths of 42, 48, and 56 (?) Inches. The frames came in 2 lengths. Older ones have the shorter frames, newer ones (since about 1968) are the longer ones. Lots of good folks here. Somebody will be along with better information. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,510 #9 Posted December 13, 2021 The small white spot above the Wheel Horse decal have a serial number on it you can read in the first photo? Share this post Link to post Share on other sites
squonk 48,215 #10 Posted December 13, 2021 I'm going to say 63'-66'. The early front engine tractor blades had the "X" bracing and the foot/ short lever side shifter for the blade angling. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,510 #11 Posted December 13, 2021 The small postage stamp size of serial sticker first showed up in 1964 following the use of the 1962 type 62-xxxxxx on tractors and the A-xxxxx on attachments. Share this post Link to post Share on other sites
stevasaurus 23,857 #12 Posted December 13, 2021 It looks like a short frame Snow Blade to me. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,510 #13 Posted December 13, 2021 1965 serial decals were also small Share this post Link to post Share on other sites
