Jon925mn 39 #1 Posted December 8, 2021 Choke cable broke on C-145 tractor. Is there a replacement available? Part # 108043 or 108045. Alternatives? Share this post Link to post Share on other sites
peter lena 9,640 #2 Posted December 8, 2021 @Jon925mn , think that cable should be a easy pick up , the important part of re cabling IS THE LAY OUT , mount it where it works best , with added cable clamp screw on tabs , and SUPER LUBE , teflon lubricant . continue to verify smooth easy function at every step , don't get to the end and find its stiff in function. I also put a light spring on each side of my end lever points , for a pull back at every use , mine work very smooth , no binding , pete Share this post Link to post Share on other sites
Gregor 4,847 #3 Posted December 8, 2021 Didn't find one but,............. Share this post Link to post Share on other sites
ebinmaine 76,423 #4 Posted December 8, 2021 @Achto What's that link you give for cables? Psep.biz ? 1 Share this post Link to post Share on other sites
peter lena 9,640 #5 Posted December 8, 2021 @Jon925mn this is my set up , very easy to add perforated mount holes to any screw or bolt , springs put a balance to cable operation , have them on my 3 horses , ever try to PUSH A CABLE ? pete Share this post Link to post Share on other sites
Gregor 4,847 #6 Posted December 8, 2021 3 minutes ago, ebinmaine said: @Achto What's that link you give for cables? Psep.biz ? Yeah, thats the bookmark I was trying to find. http://www.psep.biz/store/toro_mower_cables.htm But I didn't find a cable there either. At least mot by those numbers. Share this post Link to post Share on other sites
Achto 30,427 #7 Posted December 8, 2021 4 minutes ago, ebinmaine said: What's that link you give for cables? Those are for the push pull type cable. The C-145 will have a lever style. 1 Share this post Link to post Share on other sites
Achto 30,427 #8 Posted December 8, 2021 23 minutes ago, Jon925mn said: Part # 108043 or 108045. Alternatives? You could pick up a new cable and sheath, then crimp it into you old lever controls. 4 Share this post Link to post Share on other sites
squonk 45,049 #9 Posted December 8, 2021 108045 is out there but $$$$ A-Z may have a good used one. 1 Share this post Link to post Share on other sites
oliver2-44 11,135 #10 Posted December 8, 2021 Parts Tree shows them available. But Ouch $71 https://www.partstree.com/search/?type=part&term=+108045 Share this post Link to post Share on other sites
Jeff-C175 7,207 #11 Posted December 8, 2021 (edited) 57 minutes ago, Achto said: You could pick up a new cable and sheath, then crimp it into you old lever controls. If the sheath is not broken you could probably just slide in a new wire. Dorman has a cheap replacement cable assembly that you could rob the wire from. Edited December 8, 2021 by Jeff-C175 2 Share this post Link to post Share on other sites
Jon925mn 39 #12 Posted December 8, 2021 Ok so removed cable. Its 41" long and unsure if thats correct as have no idea what PO did. The end at carb if fine but at lever its broke. Seems like cable might be long enough to cut and bend new s hook. Does anyone drill out those stupid rivets and whats an easy way to bend the end. Thanks all for the helpful suggestions. Share this post Link to post Share on other sites
ebinmaine 76,423 #13 Posted December 8, 2021 2 minutes ago, Jon925mn said: easy way to bend the end I've been using one or two pairs of good quality thick needle nose pliers for several years. I have very good grip strength so it hasn't been an issue. Recently I picked up a Z Bender. Should have purchased one of those years ago.. Share this post Link to post Share on other sites
Gregor 4,847 #14 Posted December 8, 2021 1 minute ago, Jon925mn said: at lever its broke. The inner wire is broke? 3 minutes ago, Jon925mn said: an easy way to bend the end. I have one of these. Works pretty nice. Once you learn how. Z-Bender Pliers 3 Share this post Link to post Share on other sites
Jon925mn 39 #15 Posted December 8, 2021 Here is picture of cable end and sheathing issue which will need to be cut to pinch again. Share this post Link to post Share on other sites
Achto 30,427 #16 Posted December 8, 2021 10 minutes ago, Jon925mn said: whats an easy way to bend the end. I altered a pair of pliers like shown in this video. Works great! 3 Share this post Link to post Share on other sites
Gregor 4,847 #17 Posted December 8, 2021 Carefully grind sheathing back 1/2". DON"T GRIND INTO WIRE !!!! You only have to grind through one side, the piece will slide off. If you don't have a bender, bending that Z tight enough with pliers can be a PITA ! You have a pic of the lever assembly? Share this post Link to post Share on other sites
Achto 30,427 #18 Posted December 8, 2021 5 minutes ago, Gregor said: Carefully grind sheathing back 1/2". DON"T GRIND INTO WIRE !!!! I just pull the wire back far enough so that I can cut strait through the sheath. 3 Share this post Link to post Share on other sites
Jon925mn 39 #19 Posted December 8, 2021 Lever pic with snow. Can the rivets be drilled out and replaced with bolt/nut. I dont have a bender so will have to swear my way to a new bend. Share this post Link to post Share on other sites
Jeff-C175 7,207 #20 Posted December 8, 2021 19 minutes ago, ebinmaine said: picked up a Z Bender 1 Share this post Link to post Share on other sites
Gregor 4,847 #21 Posted December 8, 2021 Any rivet can be drilled out and replaced with a bolt I would think. Trouble is getting, and keeping the correct pressure on the lever assembly. A wave washer, or 2 , would be nice. I have used these when space allows. You don't have to bend the wire, and it gives you another adjustment point. Grind off that L shaped part. You don't need it. After looking at your lever, I don't think this little gizmo would work. No room for that Phillips head screw., I don't think, but can't really tell. 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #22 Posted December 8, 2021 30 minutes ago, Achto said: altered a pair of pliers One of my projects for today! 1 Share this post Link to post Share on other sites
Achto 30,427 #23 Posted December 8, 2021 22 minutes ago, Jon925mn said: Can the rivets be drilled out and replaced with bolt/nut. Definitely. Share this post Link to post Share on other sites
ebinmaine 76,423 #24 Posted December 8, 2021 43 minutes ago, Gregor said: Any rivet can be drilled out and replaced with a bolt I would think. Trouble is getting, and keeping the correct pressure on the lever assembly. A wave washer, or 2 , would be nice. I have used these when space allows. You don't have to bend the wire, and it gives you another adjustment point. Grind off that L shaped part. You don't need it. Have you used those long-term and do you find that they hold well after a fair amount of usage? Share this post Link to post Share on other sites
Jon925mn 39 #25 Posted December 8, 2021 FIXED! No cost but a little time. Was able to bend with couple pliers and death grip. Works like butter with no binding. Very thankful for replies by members as it always makes the task doable. Big storm coming Friday and tractor is ready to go. Safe holidays everyone! 1 5 Share this post Link to post Share on other sites
