clueless 3,325 #1 Posted December 7, 2021 What size roll pin punch does the steering wheel pin take? Share this post Link to post Share on other sites
rmaynard 16,651 #2 Posted December 7, 2021 I believe most are 1/4" 2 1 Share this post Link to post Share on other sites
squonk 44,754 #3 Posted December 7, 2021 1/4" hitch pin or bolt fits in the hole. 1 Share this post Link to post Share on other sites
Achto 30,048 #4 Posted December 7, 2021 Yep 1/4" roll pin punch is what you need. If it will not drive out, like commonly happens. Then you will need an inexpensive 1/4" carbide tipped concrete drill bit or a high dollar full carbide bit to drill it out. These are the only type of bits that will even think about drilling through a roll pin. 1 Share this post Link to post Share on other sites
ri702bill 10,317 #5 Posted December 7, 2021 @Achto Roger that - it's ALL about the speed & feed of that drill.... Bill Share this post Link to post Share on other sites
Achto 30,048 #6 Posted December 8, 2021 11 minutes ago, ri702bill said: it's ALL about the speed & feed of that drill... If you use a carbide tipped concrete bit, throw out every thing that you have been taught about drilling through steel. Run your speed fast and push hard. Instead of slow speed and hard pressure. 2 Share this post Link to post Share on other sites
