JimSraj 585 #1 Posted December 3, 2021 So I’m reassembling/rebuilding a K301 on a 1967 Raider and as I’m checking the PTO cone I notice that the seal seems to be leaking. Starburst pattern of grease on the inside of the flat part of the cone that is next to the clutch plate. Does anyone have a source for replacement seal? The bearing looks to be ok. All the rollers are in place and as far as I can tell the race is ok too. It’s 1-1/2” diameter PTO sleeve over the crank. Share this post Link to post Share on other sites
oliver2-44 11,735 #2 Posted December 3, 2021 This post may have the information you need 1 Share this post Link to post Share on other sites
squonk 48,076 #3 Posted December 3, 2021 Outer brg Napa PP204RR6 $5.29 Seal Napa 14810 $9.29 Bearing should be in stock. Seal would probably need to be ordered 2 Share this post Link to post Share on other sites
