Bill D 3,213 #26 Posted December 31, 2021 On 12/1/2021 at 10:18 PM, Lee1977 said: This is what I used. It's the same flange bearing as on the lower shaft. I just line up to center the existing hole. I used a used flange bearing just like that one to fix the steering column on a 312-8. Worked great. Share this post Link to post Share on other sites
peter lena 10,125 #27 Posted December 31, 2021 @Mustang67ford your bearing pictures to dash face area , is not the point of mounting , once you mount bearing on a clean smooth shaft , behind dash , you are free to find the best mount spot . easily sliding bearing and adding to the horizontal cross brace , will find your spot . done this set up on my horses , along with related , wiring , pto lever improvement and , clean up , on a number of issues. this not a perfect swap out , but it does fit and work . use your existing damaged dash face as a templet for a less damaged one . easily sliding bearing on shaft , behind dash will show you your new mount point , pete Share this post Link to post Share on other sites
Mustang67ford 234 #28 Posted December 31, 2021 28 minutes ago, peter lena said: @Mustang67ford your bearing pictures to dash face area , is not the point of mounting , once you mount bearing on a clean smooth shaft , behind dash , you are free to find the best mount spot . easily sliding bearing and adding to the horizontal cross brace , will find your spot . done this set up on my horses , along with related , wiring , pto lever improvement and , clean up , on a number of issues. this not a perfect swap out , but it does fit and work . use your existing damaged dash face as a templet for a less damaged one . easily sliding bearing on shaft , behind dash will show you your new mount point , pete I have a new steering shaft. Do you have pics of an install? I thought it mounted to the upper dash lip. Share this post Link to post Share on other sites
Lee1977 7,813 #29 Posted December 31, 2021 48 minutes ago, Mustang67ford said: I have a new steering shaft. Do you have pics of an install? I thought it mounted to the upper dash lip. That is how I mounted mine. 1 Share this post Link to post Share on other sites
peter lena 10,125 #30 Posted December 31, 2021 @Mustang67ford yes it does mount to the dash lip , if you need more space , use the bottom of the lip, like i said when setting this up , take advantage of what ever space you need . I also added more strength to the cross angle steel . don't have pics , always been a PIA to load and transfer . pete Share this post Link to post Share on other sites
