Snoopy11
457 Timing Advance
Snoopy11
Hey guys,
I mentioned this in the "What have you done to your Wheel Horse today" thread. But I thought it is a good idea to go into a little more detail of what I did today.
So... I have an adjustable timing flywheel on my 457... which I had previously set conservatively. I had 34 degrees of advance.
What I did, is put in 6 more degrees of advance after talking to ARC Racing a couple of days ago.
I did attempt more timing advance, however, the cylinder head temp went up WAY too high. I could run more timing advance in a competition environment, however, as a working tractor, I do not think that more advance is reliable.
Obviously, I had to rejet the carb... which I hate doing... but the end result was well worth it.
I am posting this, just in case other guys try something like this in the future with these racing engines. It can be done, but I would not go higher than 40 degrees of advance, outside of competitions.
Don
Snoopy11
Oh, and just in case anyone is wondering... I did change cams since my last videos, thus why its idle does indeed sound different than my previous videos. :thumbs:
DOn
Maxwell-8
What is the gain?
Snoopy11
15 minutes ago, Maxwell-8 said:
What is the gain?
Well, the cam and timing advance gained me around 150 rpm... which doesn't sound like much. However, the torque also increases throughout the powerband. :thumbs:
Don
Snoopy11
I would also say, it runs much smoother up through the powerband... :thumbs:
Don
