grinchsr 651 #1 Posted November 22, 2021 Looking for ideas on how to repair the crack. I was thinking JB Weld or 2 part epoxy after I open up the crack a little more to make room for what ever I use. Open to ideas Share this post Link to post Share on other sites
ebinmaine 75,024 #2 Posted November 22, 2021 Does it flex and move when you pull on the steering wheel? Certainly something to consider when choosing the appropriate repair chemical. I was reminded of another product this past weekend called 3M Structural Adhesive. I don't know if it would fit your needs so check into it. Share this post Link to post Share on other sites
grinchsr 651 #3 Posted November 22, 2021 Didn’t check for that. I will check into the 3M product. They make good adhesive 1 Share this post Link to post Share on other sites
ri702bill 10,317 #4 Posted November 22, 2021 All: That looks way too familiar. The crack will only get worse, then the wheel will fail as it seperates from the metal hex hub. Randy L posted a thread on November 10th titled Bent Steering Wheel. I posted what happened to the wheel on the C81 while plowing and my permanent fix. Bill Share this post Link to post Share on other sites
oliver2-44 11,028 #5 Posted November 22, 2021 If the crack is not fixed water will get to the steel insert in the wheel and cause it to rust. The rust will gradually separate the wheel from the plastic. I've used JB Weld and PC7 for steering wheel repair. In my case I liked the PC7 as it was a little thicker and did not run on a curved surface. I put tape on each side of my repair areas to minimize extra cleanup. While it's hard to sand, it worked down good with a file. I filed it close to desired surface level and then finish sanded it smooth. Spray some black enamel gloss spray paint into the mixed epoxy to turn it black. It will help hide the repair. 1 Share this post Link to post Share on other sites
Skwerl58 770 #6 Posted November 22, 2021 I have repaired a few things with JB Weld Plastic Weld and it has worked well on them. I repaired my Nissan trucks radiator filler neck and it has help up great. The plastic weld that I have used dries a glossy black. 3 Share this post Link to post Share on other sites
grinchsr 651 #7 Posted November 23, 2021 Thanks for all the replies 1 Share this post Link to post Share on other sites
