CletisNester 16 #1 Posted November 18, 2021 Can anyone tell me the correct Part Number for A Kohler 301S Engine, Flywheel End, Oil Seal? I have ordered from three different sources, but I keep getting the wrong Seal. The Shaft Diameter on the flywheel end is 1.5 inches. The seal recess in the end plate is 1.985 Inches. The seal needs to be a few thousands of an inch over two inches to effect a press fir seal. Any Help would be much appreciated . Sincerely, Cletis M. Nester, ncletis@yahoo.com. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,741 #2 Posted November 18, 2021 Not aware of the seal dimensions being available. If we knew the seal part numbers there may be a way to get their dimensions. Can you post the spec number off the engine? Share this post Link to post Share on other sites
CletisNester 16 #3 Posted November 19, 2021 Spec Number for my Kohler K301S is 47812 20 hours ago, gwest_ca said: Not aware of the seal dimensions being available. If we knew the seal part numbers there may be a way to get their dimensions. Can you post the spec number off the engine? Share this post Link to post Share on other sites
Searcher60 209 #4 Posted November 20, 2021 11 hours ago, CletisNester said: Spec Number for my Kohler K301S is 47812 Kohler part number is in this link, along with dimensions. Common seal, Should be able to get one anywhere. See Kohler manual for correct installation depth in cover. https://powermowersales.com/stens-495-622 Share this post Link to post Share on other sites
Gregor 4,847 #5 Posted November 20, 2021 (edited) 4703206s poke here Edited November 20, 2021 by Gregor Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,741 #6 Posted November 20, 2021 2 hours ago, Gregor said: 4703206s Is this not correct? Share this post Link to post Share on other sites
