Mustang67ford 234 #1 Posted November 9, 2021 I have a 414-8, what I believe to be a 1986 year. All the wiring schematics I have found show it to be a 3a charging system with a separate ac feed to the lights that only work while its running. However, my lights work anytime even without the key. How do I confirm what charging system I have and the correct schematic? Share this post Link to post Share on other sites
Maxwell-8 4,371 #2 Posted November 9, 2021 (edited) 1 hour ago, Mustang67ford said: I have a 414-8, what I believe to be a 1986 year. All the wiring schematics I have found show it to be a 3a charging system with a separate ac feed to the lights that only work while its running. However, my lights work anytime even without the key. How do I confirm what charging system I have and the correct schematic? If it's the original engine, It should have a 15amp charging system. Does the kohler have a one of these? if so , you have a 15 amps charging system. I am guilty of putting my headlights on a separate switch, so I can turn them on at any time. for example doing some work at the evening,.. portable lamp and transport in one Edited November 9, 2021 by Maxwell-8 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,067 #3 Posted November 9, 2021 Sounds like the headlamp wiring has been changed to be powered off the battery. The lamps should not light with the key OFF if wired correctly. Where the wires come out of the engine tins one of them should have a diode covered with tape on the engine side of that connector. Feel that area for a 3/16" x 5/16" diode. You should also not have a 3-wire voltage regulator. It would be mounted in the blower housing for cooling or a large aluminum finned regulator mounted on the chassis somewhere. Post the engine spec number if you have it. 1 Share this post Link to post Share on other sites
Mustang67ford 234 #4 Posted November 9, 2021 5 hours ago, Maxwell-8 said: If it's the original engine, It should have a 15amp charging system. Does the kohler have a one of these? if so , you have a 15 amps charging system. I am guilty of putting my headlights on a separate switch, so I can turn them on at any time. for example doing some work at the evening,.. portable lamp and transport in one Dont see that, my motor is a k321s. Share this post Link to post Share on other sites
Mustang67ford 234 #5 Posted November 9, 2021 5 hours ago, gwest_ca said: Sounds like the headlamp wiring has been changed to be powered off the battery. The lamps should not light with the key OFF if wired correctly. Where the wires come out of the engine tins one of them should have a diode covered with tape on the engine side of that connector. Feel that area for a 3/16" x 5/16" diode. You should also not have a 3-wire voltage regulator. It would be mounted in the blower housing for cooling or a large aluminum finned regulator mounted on the chassis somewhere. Post the engine spec number if you have it. Spec number 60440. Here is a pic, yellow wires, Might be a diode but much smaller. Share this post Link to post Share on other sites
Maxwell-8 4,371 #6 Posted November 9, 2021 9 minutes ago, Mustang67ford said: Dont see that, my motor is a k321s. How sorry, I thought they started using the M14 in 1986.. My bad Do you find a heatsink somewhere? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,067 #7 Posted November 9, 2021 Your tractor is a 1986 model 31-14K801 Share this post Link to post Share on other sites
Mustang67ford 234 #8 Posted November 9, 2021 (edited) 49 minutes ago, gwest_ca said: Your tractor is a 1986 model 31-14K801 I was thinking that but very small in size. How else to verify without undoing heat shrink? I was getting roughly 20vac across the 2 yellow wires at the plug with it plugged in and running. Also, if it were 3a system, what wire would have went to the lights? The yellow wire without the possible diode is grounded which would match the schematic I think. Edited November 9, 2021 by Mustang67ford Share this post Link to post Share on other sites
Mustang67ford 234 #9 Posted November 9, 2021 2 hours ago, Maxwell-8 said: How sorry, I thought they started using the M14 in 1986.. My bad Do you find a heatsink somewhere? Dont see a heat sink. Share this post Link to post Share on other sites
pfrederi 20,062 #10 Posted November 9, 2021 Where do the3 wires go... one to the ignition switch I terminal (for the coil) one directly to the light switch (or maybe ACC on the igntion switch) the other to R or B on the ignition switch?? if so 3 amp system. Share this post Link to post Share on other sites
Mustang67ford 234 #11 Posted November 10, 2021 4 hours ago, pfrederi said: Where do the3 wires go... one to the ignition switch I terminal (for the coil) one directly to the light switch (or maybe ACC on the igntion switch) the other to R or B on the ignition switch?? if so 3 amp system. Thanks, I'll look into that. Got sidetracked when I realized the circuit board for the indicator lights has been removed. Wiring is there but no board. Guessing there has been more modifications to the electrical than expected. Share this post Link to post Share on other sites
