Gregor 4,848 #1 Posted November 4, 2021 My present project is going to need some wheels at the end. I know I can get polished aluminum wheels from Miller Tire, but I'd like to find something a little different. I like these.They remind me of dark center Keystones from my younger days. Anyone know of a place I might be able to find some other options besides polished aluminum? 2 Share this post Link to post Share on other sites
roadapples 6,987 #2 Posted November 4, 2021 I'd have a set of those on my truck if it wasn't 6 lug... Share this post Link to post Share on other sites
ebinmaine 80,464 #3 Posted November 5, 2021 Did some poking around a bit this morning. I find those particular rims are American Racing Torque Thrust available in 14 or 15 inch. I figured you already knew that though... Maybe a UTV/ATV wheel shop has something in a classic style? 2 Share this post Link to post Share on other sites
peter lena 10,030 #4 Posted November 5, 2021 @Gregor lots of similar american racing old school type of wheels on line , just match pricing and shipping against each of them . was looking for steel " holed " wheels for my ride and found a bunch of sights , just my insight , pete Share this post Link to post Share on other sites
Gregor 4,848 #5 Posted November 5, 2021 Gonna make some calls today. There are lots of wheels out there, but ATV/UTV wheels are usually 4 bolt. I don't know if the is an adapter to go from 5 / 4.5 to 4 bolt. Share this post Link to post Share on other sites
ebinmaine 80,464 #6 Posted November 5, 2021 40 minutes ago, Gregor said: adapter I see them available and they're not cheap but they're a set of 4. I'm thinking you could buy the appropriate spacers you'll likely need for the wheels you choose and drill as necessary. Share this post Link to post Share on other sites
Joe 77 B100 84 #7 Posted November 6, 2021 I was just given a b100 I plan to use only to blow snow and it needs new front tires. Should I get lugs or ribs? The present turf tires are 16x6.5x8. Will I need a different size if I go lug or rib? Thanks. Total newbie. 1 Share this post Link to post Share on other sites
ebinmaine 80,464 #8 Posted November 6, 2021 7 hours ago, ecojoe69 said: I was just given a b100 I plan to use only to blow snow and it needs new front tires. Should I get lugs or ribs? The present turf tires are 16x6.5x8. Will I need a different size if I go lug or rib? Thanks. Total newbie. Best bet on the front is a set of turfs with #40 roller chain wrapped around the center of them. The chain effectively makes the rib of a tri rib but in metal so it gives excellent steering traction. 2 Share this post Link to post Share on other sites
Handy Don 17,384 #9 Posted November 6, 2021 (edited) 9 hours ago, ebinmaine said: Best bet on the front is a set of turfs with #40 roller chain wrapped around the center of them. The chain effectively makes the rib of a tri rib but in metal so it gives excellent steering traction. @ecojoe69 With the cautions that: a) the metal could scratch the surface from which you are clearing snow, and b) the combo of chain length (slightly caving in the uninflected tire) and tire pressure (enough to swell the tread up a bit alongside the chain) is important to keep the chain from sliding off! If scratching will be an issue, then the consensus seems to be that ribs or turfs with a LOT LOT LOT of weight in front is the way to keep traction. (IMHO, lugs look cool, but only really affect grip on powered wheels.) Edited November 6, 2021 by Handy Don 2 Share this post Link to post Share on other sites
Gregor 4,848 #10 Posted November 9, 2021 I get easily confused on tire sizes. I just don't buy that many I guess.If I am reading this right, these tires are 26" high, 11" wide, for a 14" rim. Is that right? Share this post Link to post Share on other sites
SylvanLakeWH 32,292 #11 Posted November 9, 2021 Yes Share this post Link to post Share on other sites
8ntruck 9,246 #12 Posted November 9, 2021 Started talking about wheels and ended up talking tires..... Back to wheels. The typical wheel horse bolt pattern is 5 on 4 1/2, or is it 5 on 5? I can't remember right now. Those are automotive bolt patterns. You should be able to get those Torque Thrust style wheels with those bolt circles in 14" and 15" diameters and in various back sspacing. Something might be out there that would fit a wheel horse. Good luck and have fun. Share this post Link to post Share on other sites
Handy Don 17,384 #13 Posted November 9, 2021 2 hours ago, Gregor said: I get easily confused on tire sizes. I just don't buy that many I guess.If I am reading this right, these tires are 26" high, 11" wide, for a 14" rim. Is that right? In another thread, you'll read laments of the trend that more and more tires actual measurements do NOT equal their published dimensions. 1 Share this post Link to post Share on other sites
ebinmaine 80,464 #14 Posted November 9, 2021 25 minutes ago, 8ntruck said: wheel horse bolt pattern is 5 on 4 1/2 Yessir. Many garden tractors are the same. Horses use a shallow back space. Share this post Link to post Share on other sites
Gregor 4,848 #15 Posted November 9, 2021 4 hours ago, Handy Don said: more and more tires actual measurements do NOT equal their published dimensions. That's what worried me. I can go 26, but NO MORE! If they are taller than that, I am in trouble. Share this post Link to post Share on other sites
ebinmaine 80,464 #16 Posted November 9, 2021 3 hours ago, Gregor said: That's what worried me. I can go 26, but NO MORE! If they are taller than that, I am in trouble. Likely you can contact one of the vendors in your pics and get a true inflated size. 1 Share this post Link to post Share on other sites
