Tedwoodbear 1 #1 Posted November 1, 2021 (edited) Hi, I have a wheelhorse lawnranger 69-73 (fibre glass body) It has the recoil start, Tecsumseh 7 or 8? hp engine. Problem is It's suddenly started running too fast and adjusting the throttle makes no difference. Moving the governer makes no difference either? I can't see anything obvious and it seems odd that the problem seems to have come from nowhere. If anyone can help it would be gratefully appreciated. Many thanks Mike. Edited November 1, 2021 by Tedwoodbear 1 Share this post Link to post Share on other sites
oldlineman 1,577 #2 Posted November 1, 2021 maybe a broken spring on the carb linkage Share this post Link to post Share on other sites
Achto 29,858 #3 Posted November 2, 2021 (edited) 4 hours ago, Tedwoodbear said: Problem is It's suddenly started running too fast and adjusting the throttle makes no difference. Moving the governer makes no difference either? Pull the air cleaner off and make sure that the butterfly still opens and closes inside the carburetor. I even had the one completely fall off once making the engine run wide open + all of the time. Edited November 2, 2021 by Achto 1 Share this post Link to post Share on other sites
Howie 900 #4 Posted November 2, 2021 Or no plate on the throttle shaft anymore because the screws came out. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,744 #5 Posted November 2, 2021 Share this post Link to post Share on other sites
Snoopy11 5,720 #6 Posted November 3, 2021 I had a similar issue with a Briggs engine. Believe it or not, it was the head gasket... Don Share this post Link to post Share on other sites
Tedwoodbear 1 #7 Posted February 10, 2022 Thanks everyone. apologies for delay in replying. I don't log on much! Share this post Link to post Share on other sites
RED-Z06 2,681 #8 Posted February 10, 2022 Throttle butterfly is probably off the shaft and wedged into the intake behind the valve. A secondary issue, if this is the case...that means it ate the screws 1 Share this post Link to post Share on other sites
