jim v 0 #1 Posted October 26, 2021 looking for a lift handle for my 1057 so I can use a snow blade, anything out there that might work??? Share this post Link to post Share on other sites
ebinmaine 74,649 #2 Posted October 26, 2021 That tractor has a piece of metal added to the side which will need to be "re-modified". Following that, most any manual lift handle from the 60s (or newer??) Should work fine. 2 Share this post Link to post Share on other sites
jim v 0 #3 Posted October 26, 2021 If anyone has anything that could work, I'd love to buy it$$ please let me know. Share this post Link to post Share on other sites
ebinmaine 74,649 #4 Posted October 26, 2021 3 minutes ago, jim v said: If anyone has anything that could work, I'd love to buy it$$ please let me know. Please do feel free to place an add in our classifieds. Meantime.. any way you can get more pics ? I'd like to see the BACK side of the area where the handle should mount to make sure you have the sheet metal still there and in good shape. And of course pics of the whole tractor because we all like pics of tractors. 😀🚜 Share this post Link to post Share on other sites
WHX?? 52,970 #5 Posted October 26, 2021 As EB said you are going to need to undo some things that have been done to that horse. You are most likely going to need the rock shaft and lift handle complete. Plus the lift stop. My guess is that someone added panels to the sides to repair the common hood stand to frame area break. .I think I see the u-shaped cutout in your hood stand. On the opposite side there should be a square metal plate about 1/4" thick on the inside of the hood stand with a hole in it that will need to be there and uncovered. I most likely would have all the pieces you need. BTW that is not a 1057 but possibly a 1067 as evidenced by the high/low shifter. There has been a few other mods to that tractor tho so all bets are off. This is what it should look like 2 Share this post Link to post Share on other sites
953 nut 62,253 #6 Posted October 27, 2021 You could give Lincoln at https://a-ztractor.com/ a call, he should have what you need. Here is a blown up drawing of the system. Shaft 9 and associated parts are for a hydraulic lift and wouldn't be used on your Share this post Link to post Share on other sites
WHX?? 52,970 #7 Posted October 27, 2021 You may want to rethink that post Richard not even close to what he has. Share this post Link to post Share on other sites
953 nut 62,253 #8 Posted October 27, 2021 11 hours ago, WHX?? said: not even close to what he has. That is the only IPL I have of the lift system, please post a better one if you have one. Share this post Link to post Share on other sites
ebinmaine 74,649 #9 Posted October 27, 2021 8 minutes ago, 953 nut said: That is the only IPL I have of the lift system, please post a better one if you have one. Do you know the year of the one you posted Richard? Looks like maybe 78 or newer? The OP's tractor is in the mid 60s but has been modified with a side plate. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,754 #10 Posted October 27, 2021 2 Share this post Link to post Share on other sites
WHX?? 52,970 #11 Posted October 27, 2021 1 hour ago, 953 nut said: post a better one if you have one. Yep my bad Richard... Garry has us covered. You would need these parts also to stop lift handle @jim v Share this post Link to post Share on other sites
