Maxwell-8 4,370 #1 Posted October 23, 2021 (edited) I have a couple of fast questions: What is the part number for 1"1/8 axles seals of a 6speed: Axle seal 100443 ? What is the part number for the shifter boot What is the carging amps on a KT17 in a Wheel Horse application? It's 15amp as I see the rectifier What is the diffrence between a C160 and a C161? What would this horse be? engine is not original Thanks for your answers, I am getting ready to make another big order of Wheelhorse parts. So I am thanking you in advance! Edited October 23, 2021 by Maxwell-8 Share this post Link to post Share on other sites
stevasaurus 23,517 #2 Posted October 23, 2021 1. Axle seals for the outer axles 100443 is SKF 11050. 2. shift boot...3577 3. ??? 4. The difference is one is "0"...the other is "1". Pretty sure it is just the year it's made. 1 Share this post Link to post Share on other sites
squonk 44,915 #3 Posted October 23, 2021 C 161 is a shaker plate model C 160 isn't 1 1 Share this post Link to post Share on other sites
Maxwell-8 4,370 #4 Posted October 23, 2021 9 minutes ago, stevasaurus said: 1. Axle seals for the outer axles 100443 is SKF 11050. 2. shift boot...3577 3. ??? 4. The difference is one is "0"...the other is "1". Pretty sure it is just the year it's made. Thanks a lot! I can start ordering parts! 1 Share this post Link to post Share on other sites
Thor27 848 #5 Posted October 23, 2021 Beside the shaker plate, the 161 also has the late model hood stand and rear mounted gas tank in common with the black hoods and 3/400 series tractors. 1 1 Share this post Link to post Share on other sites
Maxwell-8 4,370 #6 Posted October 23, 2021 (edited) thanks! Edited October 23, 2021 by Maxwell-8 Share this post Link to post Share on other sites
Thor27 848 #7 Posted October 23, 2021 Shaker plates were used on singles too 1 Share this post Link to post Share on other sites
Maxwell-8 4,370 #8 Posted October 23, 2021 (edited) 2 minutes ago, Thor27 said: Shaker plates were used on singles too I just noticed. Hard to know what that horse was, but I know now it's a C ending with a 1 since I do have the fuel tank in the back. there is no sign of a shakerplate anymore tho. Edited October 23, 2021 by Maxwell-8 Share this post Link to post Share on other sites
Thor27 848 #9 Posted October 23, 2021 (edited) Being it's not the original engine throws in other variables, If i recall when that was on the 175, it is a big pan designed for use with out a shaker plate. a M16 is a powerful engine, you are handicapping the tractor by not having the PTO operational imho. edit: the M16 was never used with a shaker plate and should not fit with. Edited October 23, 2021 by Thor27 add Share this post Link to post Share on other sites
stevasaurus 23,517 #10 Posted October 23, 2021 Got a model number ?? Is it a made in Belgium horse. Anything is possible if made there. Share this post Link to post Share on other sites
953 nut 63,121 #11 Posted October 23, 2021 4 hours ago, Maxwell-8 said: What is the carging amps on a KT17 in a Wheel Horse application? It's 15amp as I see the rectifier Yes, 15 amps. Share this post Link to post Share on other sites
