Tinman1962 15 #1 Posted October 22, 2021 Very new haven't got a manual yet like to see spring placement on1054a 10hp kohler 1 Share this post Link to post Share on other sites
Achto 31,011 #2 Posted October 22, 2021 (edited) There should not be a spring on the carburetor. There will be a spring on the governor, this spring is going to be very specific to the engine as it controls the RPMs. did not publish a manual for the engines on their tractors, you will need the Kohler manual to service the engine. Here is a link to the manuals for your tractor. Edited October 23, 2021 by Achto 1 Share this post Link to post Share on other sites
peter lena 9,764 #3 Posted October 22, 2021 @Achto , years ago , was having a carb linkage issue , tracking it down , found the culprit was at the governor shaft area , started penetrating oil working on it , rust started coming out , that was the entire trouble spot . detailed every movement point with lube , and regularly shoot both ends of that governor shaft , no more issues, governor follow is consistent , do this on my 3 kohler magnums , smooth , pete 1 1 Share this post Link to post Share on other sites
Maxwell-8 4,370 #4 Posted October 22, 2021 Do you mean the governor spring, like her down low on this trottle arm? Share this post Link to post Share on other sites
Achto 31,011 #5 Posted October 23, 2021 2 hours ago, Tinman1962 said: Very new haven't got a manual yet like to see spring placement on1054a 10hp kohler carb Check your post from yesterday. I set you up with manuals. 1 Share this post Link to post Share on other sites
stevasaurus 23,617 #6 Posted October 23, 2021 So did I...with both the 1054 & 1054A. They are in the "Manuals Section" on the main page. Share this post Link to post Share on other sites
