TJ5208 1,841 #1 Posted October 19, 2021 (edited) would a stack limit power because I have a Ih1 stack I want to put on rebel but I didn't know if it would lower power how big is the exhaust port Edited October 19, 2021 by TJ salyers Share this post Link to post Share on other sites
Maxwell-8 4,367 #2 Posted October 19, 2021 (edited) Don't think you are going to notice a power increase/decrease. these small engines don't rev high enhough for it to have influence. Is that the fuel hose going trough the engine cover? Edited October 19, 2021 by Maxwell-8 1 Share this post Link to post Share on other sites
pfrederi 18,971 #3 Posted October 19, 2021 7 minutes ago, Maxwell-8 said: Don't think you are going to notice a power increase/decrease. these small engines don't rev high enhough for it to have influence. Is that the fuel hose going trough the engine cover? Yes Very common Techy design... 1 Share this post Link to post Share on other sites
TJ5208 1,841 #4 Posted October 19, 2021 To ask how big is the exhaust port need to get some pipes Share this post Link to post Share on other sites
Achto 29,857 #5 Posted October 19, 2021 3 minutes ago, TJ salyers said: To ask how big is the exhaust port need to get some pipes I match the port size on the engine and then usually step up to a larger pipe. If your using an IH muffler, I believe that it is designed to be a slip fit over 1" water pipe. 1 Share this post Link to post Share on other sites
Snoopy11 5,720 #7 Posted October 20, 2021 6 hours ago, Maxwell-8 said: Don't think you are going to notice a power increase/decrease. these small engines don't rev high enhough for it to have influence. True... but also depends on the size of the pipe and length of the stack. Longer length you run, bigger pipe might be helpful... Don 1 Share this post Link to post Share on other sites
briankd 819 #8 Posted October 21, 2021 On 10/19/2021 at 11:48 AM, TJ salyers said: would a stack limit power because I have a Ih1 stack I want to put on rebel but I didn't know if it would lower power how big is the exhaust port I put the ih1 stack on my c 120 no problems had to build a bracket to reiforce it from moveing 1 Share this post Link to post Share on other sites
