TJ5208 1,841 #1 Posted October 19, 2021 How would I go to get a engine running after 12 years of sitting the engine is on rebel and it is a HH100 Tecumseh 115145B Share this post Link to post Share on other sites
Maxwell-8 4,367 #2 Posted October 19, 2021 (edited) 5 hours ago, TJ salyers said: How would I go to get a engine running after 12 years of sitting the engine is on rebel and it is a HH100 Tecumseh 115145B Check if it turns over by hand, and see if it has compression and OIL! start to see if you have spark, probably need to sand the points. spray some gasoline in the carb and see if it fires. If yes clean the carb and do some maintance Edited October 19, 2021 by Maxwell-8 1 1 Share this post Link to post Share on other sites
8ntruck 8,154 #3 Posted October 19, 2021 Starting fluid is OK for big engines, but it is capable of damaging small engines. You are better off using carb cleaner or gas as a starting fluid. 1 2 Share this post Link to post Share on other sites
TJ5208 1,841 #4 Posted October 19, 2021 It tried the starter seems a little slow maybe the battery im gonna try to jump it off the 2nd gen tommorow. When I turn it by hand the compression is exelent should I put oil in the spark plug hole I won't forget to close the valves Share this post Link to post Share on other sites
peter lena 9,456 #5 Posted October 19, 2021 @TJ salyers would hook it up to a separate gallon jug of gas and seafoam , Stabil gas treatment , start it up slowly , don't run it hard after its long sleep. having done this , run it till hot and responding with no trouble , would also do a hot oil change at that point , a fresh lubrication start , is what i have done , pete Share this post Link to post Share on other sites
Snoopy11 5,720 #6 Posted October 20, 2021 8 hours ago, TJ salyers said: How would I go to get a engine running after 12 years of sitting the engine is on rebel and it is a HH100 Tecumseh 115145B Buddy, you want my advice from an engine guy... buy some molly lube, take it apart, check everything for wear, rebuild. Not saying you couldn't get lucky and have the engine run right off the bat, and maybe for another 20 years, but I always like to be sure... just in case that thing is a ticking time-bomb... literally and figuratively. Just keep in mind, if you don't take it apart and rebuild, you are taking a chance on the crankshaft journal. The cam lobes and followers will get lubricated by the below process... but the crankshaft journal may not receive lubrication on startup... I think, this is what I would fear the most here... lack of oil on startup. If you don't want to take it apart, what I would do is put oil in the engine and rotate it every-which-way... flipping the engine over, shaking it to get the oil everywhere. You can put oil in the spark plug hole, and rotate the engine over... this will help get the rings and piston wall lubed-up ( @Jeff-C175 knows what I mean there... )... Me being me... I would also take the pushrods out and put a couple of drops of oil down in the holes to get the followers lubricated... Again, all of this is worthy of mention... whether you do any of this is completely up to you. Again, you could start it up, run it without issue. BUT... worthy to mention that you might also get unlucky... Don 1 Share this post Link to post Share on other sites
Jeff-C175 7,206 #7 Posted October 20, 2021 20 minutes ago, Snoopy11 said: ( @Jeff-C175 knows what I mean there... )... 1 Share this post Link to post Share on other sites
TJ5208 1,841 #8 Posted October 20, 2021 Rebel is running check out my YouTube TJ salyers Share this post Link to post Share on other sites
TJ5208 1,841 #9 Posted October 20, 2021 When I started him I wanted to see if it would pull it self when I let out on the clutch it broke the drive belt what is the model number of the belt I need Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,742 #10 Posted October 20, 2021 1970 Raider 10 model 1-6051 Click on the tractor to see the drive belt used 1 Share this post Link to post Share on other sites
TJ5208 1,841 #11 Posted October 21, 2021 Thank you can I buy one from toro Share this post Link to post Share on other sites
TJ5208 1,841 #12 Posted October 21, 2021 This is the model of the belt on Rebel Share this post Link to post Share on other sites
Achto 29,848 #13 Posted October 21, 2021 Looking at the manual it calls for a 5/8 x 82" belt. Should be able to find one at your local hardware store. 1 Share this post Link to post Share on other sites
TJ5208 1,841 #14 Posted October 21, 2021 Would it hurt to go with a 80 inch for extra grip Share this post Link to post Share on other sites
Achto 29,848 #15 Posted October 21, 2021 Just now, TJ salyers said: Would it hurt to go with a 80 inch for extra grip If you can get it to go on, it would not loosen up enough to allow you to shift gears when you step on the clutch. 1 Share this post Link to post Share on other sites
TJ5208 1,841 #16 Posted October 21, 2021 Just wanted to know because I thought it would work worth asking 1 Share this post Link to post Share on other sites
TJ5208 1,841 #17 Posted October 21, 2021 I also seen some other type drive belts that are rigged on the inside of the belt is there any difference in them Share this post Link to post Share on other sites
Achto 29,848 #18 Posted October 21, 2021 No need to go with anything special. A normal kevlar will last a long time and have plenty of grip. I use the Husky brand belts from Tractor Supply, but any kevlar belt should work with out issue. 1 Share this post Link to post Share on other sites
Snoopy11 5,720 #19 Posted October 21, 2021 2 hours ago, Achto said: No need to go with anything special But the best Kevlar belts come from Bando. If you want... you can call Bearings and Industrial Supply... who can get you any belt you want/need. They are based out of Illinois... Tell them what belt you want, they will go down to Bando headquarters, pick up the belt, and ship it to you. (630) 628-1966 Don Share this post Link to post Share on other sites
