Retired Wrencher 6,062 #1 Posted October 18, 2021 I have a B80/8 and now it does not turn over it ran on Saturday. Cleaned all connections new battery new switch. Dead. Lucky I have summer clean B 80 to take parts off and try and see if this works. Any thoughts? Share this post Link to post Share on other sites
pfrederi 18,972 #2 Posted October 18, 2021 (edited) Assume it is original engine K-181 battery ignition and solenoid. Switch in start do you have 12v at the small terminal on solenoid?? Edited October 18, 2021 by pfrederi Share this post Link to post Share on other sites
sparkie333 265 #3 Posted October 18, 2021 I agree first I would check ---(as stated above)-- the 12v at the solenoid---But I do know that the Switch needs to be a match--in most cases. Good Luck. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,744 #4 Posted October 18, 2021 1977? 1976 may be different Share this post Link to post Share on other sites
Retired Wrencher 6,062 #5 Posted October 18, 2021 Well Guys I used a jumper box and the starter works. So I am thinking it the solenoid. Will keep you posted. Share this post Link to post Share on other sites
Retired Wrencher 6,062 #6 Posted October 18, 2021 Just now, gwest_ca said: 1977? 1976 may be different Thanks Garry. Share this post Link to post Share on other sites
Handy Don 14,663 #7 Posted October 18, 2021 1 hour ago, Retierd Wrencher said: Well Guys I used a jumper box and the starter works. So I am thinking it the solenoid. Will keep you posted. Don't ignore the possibilities of a bad ignition switch or switch-to-solenoid wiring/connections. 2 Share this post Link to post Share on other sites
sparkie333 265 #9 Posted October 19, 2021 22 hours ago, Retierd Wrencher said: Well Guys I used a jumper box and the starter works. So I am thinking it the solenoid. Will keep you posted. Any more updates? Share this post Link to post Share on other sites
Retired Wrencher 6,062 #10 Posted October 20, 2021 Sparkie thanks for the replay. It was the starter solenoid. 2 Share this post Link to post Share on other sites
