dwcphoto 7 #1 Posted October 10, 2021 Good day folks, I have a 518-H. It would not start yesterday, turning over without issue. I suspected the vacuum line and sure enough it was hanging free on the dash end. I noticed the fitting has broken off and is in the tube. I can't seem to find where it goes. I want to either replace the part or try to repair it. Any ideas? Thank you, David Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #2 Posted October 10, 2021 Item #37 in the top right corner https://www.partstree.com/models/31-18oe01-518-h-toro-garden-tractor-1988/electrical-system-12/ Share this post Link to post Share on other sites
dwcphoto 7 #3 Posted October 10, 2021 Thank you! Now I know where to look. I'll see if I can pull it out and inspect. Much appreciated! dwc 1 Share this post Link to post Share on other sites
ri702bill 11,260 #4 Posted October 10, 2021 DWC You can plug the vacuum line - a golf tee works great for this. That will get you going until you can do a proper fix ..... Bill 2 Share this post Link to post Share on other sites
Ed Kennell 44,903 #5 Posted October 10, 2021 What is the purpose of a vacuum gage? Is there a "safe " range? Share this post Link to post Share on other sites
squonk 45,535 #6 Posted October 10, 2021 17 minutes ago, Ed Kennell said: What is the purpose of a vacuum gage? Is there a "safe " range? You get to watch that needle go back and forth when that Onan is hunting at idle. Kinda hypnotizing! 4 Share this post Link to post Share on other sites
dwcphoto 7 #7 Posted October 10, 2021 My 518-H does not have a vacuum gauge. It looks like the hose might have gone to a small, black box that says World Magnetics on it. That sound familiar? dwc Share this post Link to post Share on other sites
cleat 8,735 #8 Posted October 10, 2021 That is the sensor for a plugged air filter. I don't have that hooked up on any of my 520's as I regularly check the air filters. 1 Share this post Link to post Share on other sites
dwcphoto 7 #9 Posted October 10, 2021 Ok. So should I replace the sensor or plug the line? I know that years ago I had trouble starting the tractor and when I replaced the old, deteriorated line, it fired right up. Thank you, dwc Share this post Link to post Share on other sites
dwcphoto 7 #10 Posted October 10, 2021 Also, there's only one hose, but it looks like it has an open port in the back. They all look like they have two places to hook up a hose when I search DesignFlex PSF102 SERIES online. Thank you! dwc Share this post Link to post Share on other sites
lynnmor 8,628 #11 Posted October 10, 2021 1 hour ago, Ed Kennell said: What is the purpose of a vacuum gage? Is there a "safe " range? Wheel Horse calls it a percentage of horsepower gauge. When running with the governor holding the throttle wide open, it will read 100%. The only practical use is informing the operator of how hard they are working the engine, and then they can decide if it should be working that hard, especially in hot weather. If one wants to keep the valve seats in place in a 20 HP Onan then knowing how hard it is working can help you determine how it should be operated. Only the 20 HP engine has significant valve seat issues, probably because of the more aggressive cam and more heat generated at wide open throttle. Running the engine slower than maximum speed will cause more throttle opening and less cooling air, so that is not a good option. Keep in mind that the lever on the dash labeled "throttle" is actually an engine speed control, the governor operates the throttle in the carburetor. Share this post Link to post Share on other sites
lynnmor 8,628 #12 Posted October 10, 2021 57 minutes ago, dwcphoto said: My 518-H does not have a vacuum gauge. It looks like the hose might have gone to a small, black box that says World Magnetics on it. That sound familiar? dwc The line from inside the air filter box goes to that switch to sense the pressure difference across the air filter media. If the difference is too great, a lamp will come on to inform the operator that the filter is dirty. I have only had that lamp come on one time and that was with a filter that appeared clean enough. Holding a lamp inside showed that it was loaded with fine dust. Those pre-filters keep the paper filter looking OK but a closer inspection is needed. There is another thread discussing the sensor if you want more information. 1 Share this post Link to post Share on other sites
dwcphoto 7 #13 Posted October 10, 2021 Sure, can you direct me to that? Thank you, dwc Share this post Link to post Share on other sites
lynnmor 8,628 #14 Posted October 10, 2021 22 minutes ago, dwcphoto said: Sure, can you direct me to that? Thank you, dwc Link There are others as well if you search. Share this post Link to post Share on other sites
Handy Don 15,950 #15 Posted October 10, 2021 1 hour ago, lynnmor said: The line from inside the air filter box goes to that switch to sense the pressure difference across the air filter media. If the difference is too great, a lamp will come on to inform the operator that the filter is dirty. I have only had that lamp come on one time and that was with a filter that appeared clean enough. Holding a lamp inside showed that it was loaded with fine dust. Those pre-filters keep the paper filter looking OK but a closer inspection is needed. There is another thread discussing the sensor if you want more information. Only three things I'll add: 1. if it wasn't already clear, keep that tube plugged it if isn't connected to the sensor so it doesn't let unfiltered air enter the carb 2. unless the disconnected tube is letting air bypass a really clogged filter, having it disconnected should make no difference in how the engine runs 3. the nipple on the other side of the little box is a pressure sensor; clever use of a single diaphragm--push from one side (pressure) or pull from the other (vacuum) to close a circuit 1 Share this post Link to post Share on other sites
Ed Kennell 44,903 #16 Posted October 10, 2021 2 hours ago, lynnmor said: Wheel Horse calls it a percentage of horsepower gauge. When running with the governor holding the throttle wide open, it will read 100%. The only practical use is informing the operator of how hard they are working the engine, and then they can decide if it should be working that hard, especially in hot weather. If one wants to keep the valve seats in place in a 20 HP Onan then knowing how hard it is working can help you determine how it should be operated. Only the 20 HP engine has significant valve seat issues, probably because of the more aggressive cam and more heat generated at wide open throttle. Running the engine slower than maximum speed will cause more throttle opening and less cooling air, so that is not a good option. Keep in mind that the lever on the dash labeled "throttle" is actually an engine speed control, the governor operates the throttle in the carburetor. I'll check my vacuum next time I use my 520. It has always been a winter machine used for snow removal and wood hauling. When I had a SS tall chute on it, I always ran the Onan @ 3200 only because it sounded much better than at 3600. I even installed a smaller drive pulley on the blower to keep the blower revs at or above design. It always worked fine. Due to lack of snow, I have switched to a 54" blade. 1 Share this post Link to post Share on other sites
Ed Kennell 44,903 #17 Posted October 10, 2021 4 hours ago, squonk said: You get to watch that needle go back and forth when that Onan is hunting at idle. Kinda hypnotizing! And I thought it was a CLEAN MY CARB indicator for the hearing challenged operators. 1 Share this post Link to post Share on other sites
lynnmor 8,628 #18 Posted October 10, 2021 9 minutes ago, Ed Kennell said: I'll check my vacuum next time I use my 520. It has always been a winter machine used for snow removal and wood hauling. When I had a SS tall chute on it, I always ran the Onan @ 3200 only because it sounded much better than at 3600. I even installed a smaller drive pulley on the blower to keep the blower revs at or above design. It always worked fine. Due to lack of snow, I have switched to a 54" blade. You will find that the horsepower will be at or near 100% most of the time while chucking snow or mowing high grass. We don’t realize how hard they work until a gauge shows the evidence. When an engine maintains its speed, we aren’t aware that it is maxed out, only when it bogs down do we know that it is overloaded. 1 Share this post Link to post Share on other sites
