Brockport Bill 2,178 #1 Posted October 7, 2021 Re: the Onan P220 carb --- Questions Re: the needle valve that is under the hinge for the float...... Is there a spring that is suppose to be around that needle ? Secondly, the needle itself has a tiny tab or almost looks like a button on top of the needle --- is that tab/button on top of needle suppose to be able to compress into the needle, or is it suppose to be firm and stationary??? I have a couple needles from a couple Onan carbs I have apart as well as a couple rebuild kits I have just gotten. Some of the needles have tab/button that compresses, the others don't compress -- are solid frozen? All advice appreciated. Share this post Link to post Share on other sites
Handy Don 15,638 #2 Posted October 7, 2021 The needles in the P218 and P220 that I've touched were both solid "button" with no spring. I would check the overall lengths since that's what determines the float height that closes the valve. I've seen springs on other carbs where the fuel feed was gravity. I'm assuming no spring here because there is a fuel pump's pressure to open that needle valve. 1 Share this post Link to post Share on other sites
Brockport Bill 2,178 #3 Posted October 7, 2021 25 minutes ago, Handy Don said: The needles in the P218 and P220 that I've touched were both solid "button" with no spring. I would check the overall lengths since that's what determines the float height that closes the valve. I've seen springs on other carbs where the fuel feed was gravity. I'm assuming no spring here because there is a fuel pump's pressure to open that needle valve. i just received the manual emailed to me from Onan ( actually Cummings ) and diagram does NOT show a spring around the needle -- but there isn't any way of telling if the top of the needle "tab/button" compresses????????? I just ordered and received an aftermarket $17carb kit - ( to see what i would get ). It included the needle - with NO spring for around needle - nor does the top of needle compress as i have found on others??? Thanks Don - any other insights are appreciated Share this post Link to post Share on other sites
Handy Don 15,638 #4 Posted October 8, 2021 7 hours ago, Brockport Bill said: i just received the manual emailed to me from Onan ( actually Cummings ) and diagram does NOT show a spring around the needle -- but there isn't any way of telling if the top of the needle "tab/button" compresses????????? I just ordered and received an aftermarket $17carb kit - ( to see what i would get ). It included the needle - with NO spring for around needle - nor does the top of needle compress as i have found on others??? Thanks Don - any other insights are appreciated I looked in the one rebuild kit for which I still have some parts. Solid needle. I am wondering if the "sliding" button permits the makers to use the same rubber-tipped needle "cylinder" with a variety of "sliding buttons" of different lengths to save on manufacturing costs. Pretty clever, if that's it. Share this post Link to post Share on other sites
Brockport Bill 2,178 #5 Posted October 8, 2021 3 hours ago, Handy Don said: I looked in the one rebuild kit for which I still have some parts. Solid needle. I am wondering if the "sliding" button permits the makers to use the same rubber-tipped needle "cylinder" with a variety of "sliding buttons" of different lengths to save on manufacturing costs. Pretty clever, if that's it. hmmm............. interesting theory Share this post Link to post Share on other sites
kpinnc 16,627 #6 Posted October 8, 2021 The button is fixed. It provides a place for the float tab slot to both raise and lower the needle as fuel levels change in the bowl. The Nikki carb (Vanguard manual) has procedures for setting the correct angle of the tab for a given application. Vanguards (14-18hp horizontal) sometimes have these carbs on them. 1 Share this post Link to post Share on other sites
Handy Don 15,638 #7 Posted October 8, 2021 6 hours ago, kpinnc said: The button is fixed. It provides a place for the float tab slot to both raise and lower the needle as fuel levels change in the bowl. Yes, this is correct on all the needles I've seen personally, yet... In this instance they are not fixed: On 10/6/2021 at 10:08 PM, Brockport Bill said: Some of the needles have tab/button that compresses, the others don't compress -- are solid frozen? Clearly the "compressible" needles can't work in the Nikki carb you note or in the Tecumseh carbs I was working on last week since the falling float wouldn't be able to pull the needle loose from its seat. The P218 and P220 are the only fuel pump-equipped engines where I've been into the carbs so I don't have wide knowledge there but the mechanism doesn't "pull" the needle to open the needle valve. As I noted earlier, I suspect that pressure from the fuel pump is adequate to open the valve once the float lowers. Share this post Link to post Share on other sites
Brockport Bill 2,178 #8 Posted October 8, 2021 thanks Don --- Share this post Link to post Share on other sites
Brockport Bill 2,178 #9 Posted October 8, 2021 7 hours ago, kpinnc said: The button is fixed. It provides a place for the float tab slot to both raise and lower the needle as fuel levels change in the bowl. The Nikki carb (Vanguard manual) has procedures for setting the correct angle of the tab for a given application. Vanguards (14-18hp horizontal) sometimes have these carbs on them. I've seen that float adjustment technique on a You Tube -- thanks for the graphic 1 Share this post Link to post Share on other sites
Handy Don 15,638 #10 Posted October 8, 2021 47 minutes ago, Brockport Bill said: thanks Don --- YMW Share this post Link to post Share on other sites
Brockport Bill 2,178 #11 Posted October 8, 2021 got the needle issue resolved -- the 520 HC is running --- thanks all for info 1 1 Share this post Link to post Share on other sites
Handy Don 15,638 #12 Posted October 8, 2021 19 minutes ago, Brockport Bill said: got the needle issue resolved -- the 520 HC is running --- thanks all for info (any pictures?) Share this post Link to post Share on other sites
Brockport Bill 2,178 #13 Posted October 11, 2021 On 10/8/2021 at 1:42 PM, Handy Don said: (any pictures?) yup - in a couple days Share this post Link to post Share on other sites
Brockport Bill 2,178 #14 Posted October 11, 2021 here are two photos of the back end of 520 HC that I disassembled,then cleaned debris, grinder to remove corrosion, etc, primed and top coat. Also removed the lift cylinder and used rebuild kit ( $17 ) to correct leak. I'll send some engine and carb project photos in couple days. Share this post Link to post Share on other sites
Brockport Bill 2,178 #15 Posted October 11, 2021 I should note this is condition I got the new to me HC - I don't abuse equipment like the way i got this one few months ago - thats why I'm doing the various repair and rehab projects on it. Share this post Link to post Share on other sites
Brockport Bill 2,178 #16 Posted October 11, 2021 Don: here is the breather unit I took off and cleaned, plus replaced the gaskets Share this post Link to post Share on other sites
Brockport Bill 2,178 #17 Posted October 11, 2021 here's the HC lift cylinder rebuild with new O rings kit 1 Share this post Link to post Share on other sites
Handy Don 15,638 #18 Posted October 12, 2021 1 hour ago, Brockport Bill said: I should note this is condition I got the new to me HC - I don't abuse equipment like the way i got this one few months ago - thats why I'm doing the various repair and rehab projects on it. The '95 520 chassis I'm using got all of the HC upgrades except the higher final gear ratio in the transaxle that boosts the top speed. Wouldn't mind having that! Share this post Link to post Share on other sites
Brockport Bill 2,178 #19 Posted October 12, 2021 this HC is an 88 yr model -- my 14 yr old grandson's HC we got is an 89 -- he used his phone app to time the speed driving around the yard he was so impressed with how fast it went Share this post Link to post Share on other sites
Brockport Bill 2,178 #20 Posted October 12, 2021 my son has the Toro version they developed in later yrs -- he has the 1998 Toro 520 Lxi -- its a huge beast Share this post Link to post Share on other sites
Handy Don 15,638 #21 Posted October 12, 2021 Yeah, that LXI is something, for sure. Brawny (except for that front axle pivot!) and lots of grunt. Share this post Link to post Share on other sites
Brockport Bill 2,178 #22 Posted October 12, 2021 we became aware shortly after getting the Lxi this spring of the pivot issue and the fix -- he isn't using it much yet since we got it but i suspect soon he'll be looking at that issue Share this post Link to post Share on other sites
lynnmor 8,384 #23 Posted October 12, 2021 8 hours ago, Brockport Bill said: this HC is an 88 yr model -- my 14 yr old grandson's HC we got is an 89 -- he used his phone app to time the speed driving around the yard he was so impressed with how fast it went The C in the model number stands for commercial. The 520H was intended for all markets and was kept to a slower speed for safety and liability reasons. 1 Share this post Link to post Share on other sites
Handy Don 15,638 #24 Posted October 12, 2021 (edited) 5 hours ago, lynnmor said: The C in the model number stands for commercial. The 520H was intended for all markets and was kept to a slower speed for safety and liability reasons. Understood, and, selling in a country as litigious as ours, valid. Nonetheless, 10mph on a straight run would be kinda fun! (That's me, cheap thrills from the guy who took a Jag XKE up to 150 on the NY Thruway in his invulnerable youth). Edited October 12, 2021 by Handy Don 1 Share this post Link to post Share on other sites
Brockport Bill 2,178 #25 Posted October 12, 2021 I have an H and HC -- maybe I should do a side by side street race -- check out the real time difference?? haha......... Boys and their toys !!!!!!!!!!!!!!! the listed spec is 7.5 versus 6.4 mph Share this post Link to post Share on other sites
