UK321 3 #1 Posted October 6, 2021 Good afternoon from the UK I'm a long time (30 years) WH fan and currently have two a 10hp raider and a 12hp c125 which I'm trying to bring back to life. Unfortunately the PO 'lost' the fuel tank (He'd fitted a Honda engine (spit)). Does anyone know the part number and whether the same tank was used on any other WH? Thanks for all and any help Martin 1 Share this post Link to post Share on other sites
Gregor 4,847 #2 Posted October 6, 2021 (edited) back to We like lots of pics. Part # 106234 I believe all C series tractors probably used the same tank. If I am wrong, someone please correct me. You don't say the year of your tractor. The following is for 1984. Edited October 6, 2021 by Gregor Share this post Link to post Share on other sites
UK321 3 #3 Posted October 6, 2021 Gregor, Thank you so much. Very helpful indeed. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,846 #4 Posted October 6, 2021 If you post the model numbers and serial numbers of both tractors there is a way to get to a list of where part numbers were used. At least a list of the illustrated parts lists a part is listed in. The only problem is many parts lists are shared by similar models of tractors so it takes some research. I don't think that happens often with fuel tanks. Share this post Link to post Share on other sites
Lee1977 7,456 #5 Posted October 6, 2021 (edited) I check the C-125, C-175, 312-8 and 414-8 all had the same no. gas tank 105234. The only one I know is different is the 520's They have a fuel gauge sending unit in the right rear corner. It could be plugged the a gasket and a home made metal plate. Do you still have the metal tank supports bolted to the fender bracket? Edited October 6, 2021 by Lee1977 Share this post Link to post Share on other sites
Gregor 4,847 #6 Posted October 6, 2021 2 hours ago, Lee1977 said: gas tank 105234. ?????? Share this post Link to post Share on other sites
Lee1977 7,456 #7 Posted October 6, 2021 1 minute ago, Gregor said: ?????? Yes, hit the wrong key. If it is a under seat gas tank most of them seem to be the same. Share this post Link to post Share on other sites
