Wheelhorse#1 1,902 #1 Posted October 4, 2021 (edited) Apparently I mashed up a couple threads on the crank,blower side getting the flywheel off. Does anyone know the pitch and size of threads on that end ? It’s a kohler 301. I’ve been trying to find the info but can’t seem too. I believe 5/8 ? I’ll need to retrace them need to buy a die . Edited October 4, 2021 by Wheelhorse#1 Share this post Link to post Share on other sites
roadapples 6,987 #2 Posted October 4, 2021 I've cleaned up threads with a small tapered file... 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #3 Posted October 5, 2021 (edited) 32 minutes ago, roadapples said: I've cleaned up threads with a small tapered file... Me too, lots of times, because I'm way too cheap to buy an expensive die for a one time use! https://www.harborfreight.com/12-piece-needle-file-set-468.html @Wheelhorse#1 Edited October 5, 2021 by Jeff-C175 1 Share this post Link to post Share on other sites
Achto 31,554 #4 Posted October 5, 2021 (edited) 4 hours ago, Wheelhorse#1 said: I believe 5/8 ? I’ll need to retrace them need to buy a die Thread size is 5/8" - 18 for the flywheel nut. Edited October 5, 2021 by Achto 1 Share this post Link to post Share on other sites
oldlineman 1,675 #5 Posted October 5, 2021 You can make a cheap thread chaser with a nut and cutting or filing groves in the threads something like a die. Works if threads are not too bad. Bob 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,902 #6 Posted October 5, 2021 17 hours ago, Achto said: Thread size is 5/8" - 18 for the flywheel nut. Thank you, that is fine threads..Thanks again. 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,902 #7 Posted October 5, 2021 5 hours ago, oldlineman said: You can make a cheap thread chaser with a nut and cutting or filing groves in the threads something like a die. Works if threads are not too bad. Bob Thanks Bob. I may have to try that next time as I already purchased a die . Share this post Link to post Share on other sites
pfrederi 20,269 #8 Posted October 6, 2021 Bought this set probably 25 years ago. One of the best tool investments I ever made.. Use it on Milittay vehicles (lots of NF) Old tractors Case and Farmall and of course lots of Wheel horses. Share this post Link to post Share on other sites
Wheelhorse#1 1,902 #9 Posted October 9, 2021 On 10/6/2021 at 2:07 PM, pfrederi said: Bought this set probably 25 years ago. One of the best tool investments I ever made.. Use it on Milittay vehicles (lots of NF) Old tractors Case and Farmall and of course lots of Wheel horses. That’s a nice looking set.I bought a tap and die set from TS it’s ok but doesn’t have larger sizes. 25 yrs ago craftsman,they were still making nice stuff, now most everything,like every thing els is China garbage …don’t get me started !😉 Share this post Link to post Share on other sites
