ebinmaine 74,485 #501 Posted January 17, 2022 1 hour ago, Horse Newbie said: I saw some Deestone at a good price… what about those ? I don't recommend the Deestone rears. They are WAY smaller than you'd expect. 1 hour ago, Horse Newbie said: Will the 10.50 wide fit ? I'm sure they'll fit the rims just fine. I don't have any newer tractors to compare sizes on. Things to consider would be: Do you remember how much room you had before disassembly? The 10.50 is maybe 1/2" per side wider obviously so did you have enough clearance? If you're going to want chains, leave extra room next to the brake drum. 1 Share this post Link to post Share on other sites
Jeff-C175 7,206 #502 Posted January 17, 2022 (edited) 16 minutes ago, Horse Newbie said: Yeah, I see what you are saying… I will have to figure which piece on the Work Horse will “float”. I guess as long as you can move that piece enough to swing that half hoop around. Thanks @Jeff-C175, I’ll just have to find a roll pin that fits one piece or the other. I think that the pin is press fit into the hoop bar from the factory and the holes in the bracket are bigger and clear the pin. If you can't find a 5/32 pin nobody would fault you if you drilled the hole out a bit and used a 3/16 ! When I did the one on my 175 I had some 10-32 brass nuts that I installed on each side of the hoop bar in order to keep the bracket thingy centered. Edited January 17, 2022 by Jeff-C175 2 Share this post Link to post Share on other sites
Horse Newbie 7,398 #503 Posted January 18, 2022 (edited) 48 minutes ago, ebinmaine said: I don't recommend the Deestone rears. They are WAY smaller than you'd expect. Don’t want small, want big ! I'm sure they'll fit the rims just fine. Cool I don't have any newer tractors to compare sizes on. Too bad Things to consider would be: Do you remember how much room you had before disassembly? No, but I can put the ones back on to measure. The 10.50 is maybe 1/2" per side wider obviously so did you have enough clearance? Yes If you're going to want chains, leave extra room next to the brake drum. Will most likely never use chains… my tractor skills are so awesome, won’t need them. Edited January 18, 2022 by Horse Newbie 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #504 Posted January 18, 2022 52 minutes ago, Jeff-C175 said: I had some 10-32 brass nuts that I installed on each side of the hoop bar in order to keep the bracket thingy centered. Oh the humanity!… not factory !… I will definitely figure something out, and those nuts were clever ! 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #505 Posted January 18, 2022 Does anybody know how much “gap” I need to set between the PTO clutch disc and the PTO clutch disc brake pad ? Seems to me I seen .0015 somewhere. Share this post Link to post Share on other sites
ebinmaine 74,485 #506 Posted January 18, 2022 Will most likely never use chains… my tractor skills are so awesome, won’t need them..... Rrriiuggghhhttt. When you get that beast finished up c'mon upta the land of ice n' snow ❄️. We'll see how far you get with plain rubbah tires. 2 Share this post Link to post Share on other sites
Jeff-C175 7,206 #507 Posted January 18, 2022 17 minutes ago, Horse Newbie said: Does anybody know how much “gap” I need to set between the PTO clutch disc and the PTO clutch disc brake pad ? Seems to me I seen .0015 somewhere. I think that's correct. Share this post Link to post Share on other sites
Horse Newbie 7,398 #508 Posted January 18, 2022 2 hours ago, ebinmaine said: Will most likely never use chains… my tractor skills are so awesome, won’t need them..... Rrriiuggghhhttt. When you get that beast finished up c'mon upta the land of ice n' snow ❄️. We'll see how far you get with plain rubbah tires. You know … chains, we don’t need no stinking chains ! … especially when we average 2” per 10 years or so… 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #509 Posted January 18, 2022 So today I worked a little more on the Work Horse Refresh… I wiped down the wiring harness and sanded the terminals and connectors. Plugged them back on after applying a dab of dielectric grease. Also put some decals on the dash/ steering tower panel and the transmission console cover. Bailey says it passed quality control. More work was done, but no pics, so I’ll post that tomorrow… 3 Share this post Link to post Share on other sites
Horse Newbie 7,398 #510 Posted January 18, 2022 @Jeff-C175 I couldn’t wait to apply some decals… makes me think I getting close… 2 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #511 Posted January 18, 2022 That wiring harness is certainly a lot friendlier than the 520H wiring harness… whew ! 1 Share this post Link to post Share on other sites
Jeff-C175 7,206 #512 Posted January 18, 2022 (edited) 14 minutes ago, Horse Newbie said: @Jeff-C175 I couldn’t wait to apply some decals… makes me think I getting close… Those panels look great! I did the same thing with mine, probably should have waited a little more cure time on the paint... but no ill effect, they look fine. OK, this is weird... mine... yours... AND, I've also got the exact same safe (although not next to the shoebox, AND, had a pet named Bailey (but it was a cat) Edited January 18, 2022 by Jeff-C175 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #513 Posted January 18, 2022 2 minutes ago, Jeff-C175 said: OK, this is weird What ?… I don’t get it. Unless you are talking about the perv-cam… Share this post Link to post Share on other sites
Jeff-C175 7,206 #514 Posted January 18, 2022 (edited) 3 minutes ago, Horse Newbie said: What ?… I don’t get it. Unless you are talking about the perv-cam… I didn't see a perv-cam ? Same shoe box, on same kind of carpet... I saw that and thought... wait... what? EH rated safety shoes that I had to have for work... when I was still working. Edited January 18, 2022 by Jeff-C175 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #515 Posted January 18, 2022 @Jeff-C175 oh I sent the perv-cam post before I read all of your post… lol. I thought you were talking about the hole in the shoe box ! Share this post Link to post Share on other sites
Horse Newbie 7,398 #516 Posted January 18, 2022 My post # 513 doesn’t mean a thing ! Share this post Link to post Share on other sites
Horse Newbie 7,398 #517 Posted January 18, 2022 11 minutes ago, Jeff-C175 said: Those panels look great! I They did not come out without some imperfections. They have some pitted rust spots that did not come out and I did not go as far as using filler primer, but they will be good enough for the girls we date, as “Diesel Creek” guy on YouTube says… 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #518 Posted January 18, 2022 Didn’t scare you away @Jeff-C175 did I ? Share this post Link to post Share on other sites
Jeff-C175 7,206 #519 Posted January 18, 2022 (edited) 4 minutes ago, Horse Newbie said: Didn’t scare you away @Jeff-C175 did I ? No! of course not! I hadda go out to the garage to hook up some battery chargers. Post 513? we're not there yet? There was some pitting in my panels too, but I got impatient and went for the second coat before it was time and it wrinkled. So I hadda wet sand it all down and when I did that and waited the right amount of time, those pits were gone, so I guess it was a good thing! Edited January 18, 2022 by Jeff-C175 Share this post Link to post Share on other sites
Horse Newbie 7,398 #520 Posted January 18, 2022 7 back up ? Share this post Link to post Share on other sites
Horse Newbie 7,398 #521 Posted January 18, 2022 For some reason the post numbers don’t update quick… almost like I have to leave the thread and when I come back they are numbered correct. Share this post Link to post Share on other sites
Jeff-C175 7,206 #522 Posted January 18, 2022 2 minutes ago, Horse Newbie said: 7 back up ? OK, that's weird too. I backed up and sure enough, there was 513... but the next one was 502... and then I refreshed the page and all was well in Whoville again. Strange! 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #523 Posted January 18, 2022 Bailey says he’s not mad because we gave him a cat name. 2 Share this post Link to post Share on other sites
Jeff-C175 7,206 #524 Posted January 18, 2022 We also had cats named Dweezil and Moon Unit. The Treasurer is a cat person. I get to name them sometimes. 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #525 Posted January 18, 2022 (edited) Back to the business at hand… I need to get a little diesel in the Work Horse trans so I can run it a little on jack stands to flush it, put in wiring harness, battery, gas tank, fuel pet cock, fuel line, new plugs, and then I should be about ready to crank ‘er up. Edited January 18, 2022 by Horse Newbie 2 Share this post Link to post Share on other sites
