boovuc 1,090 #1 Posted June 16, 2009 What I was wondering was, since I had to rethread it, I did everything I could to remove any shavings but.......I know better in thinking I got them all. What do you think? My opinion was it was better to rethread than to not grease it! The PO did little on this tractor before I got it! Share this post Link to post Share on other sites
Sparky-(Admin) 24,646 #2 Posted June 17, 2009 I think your right about being better to grease than not to grease. Mike....... Share this post Link to post Share on other sites
gwgdog66 23 #3 Posted June 17, 2009 Considering there probably wasn't much grease in it from the previous owner, it will more than likely need to be replaced soon anyway. If it feels like it is turning fairly smooth, I'd fill it up with good quality grease and mow with it. What few slivers are in it from the rethread can't hurt it anymore than the previous owner's lack of preventive maintenance. Share this post Link to post Share on other sites
boovuc 1,090 #4 Posted June 17, 2009 Thanks for the comments, guys. It moves freely and the bearing doesn't wobble. I could luck out. Who knows....maybe it fell off or was knocked off when he took the mower off last season. I doubt it since the threads were screwed on it. In any event, I feel better with grease in it, shavings or no shavings. Share this post Link to post Share on other sites
Don1977 605 #5 Posted June 17, 2009 The base lift bracket hits mine and has wore the top off. I just screw it out and put in a good grease fitting to grease it then remove and replace the worn one. Share this post Link to post Share on other sites
