chipwitch 73 #1 Posted September 4, 2021 I'm sorry for asking this, but I have spent a couple hours searching and reading and still can't find the definitive answers... I have a C-165 but it may be a C-175 with a C165 hood. The serial number indicates a 175. How can I identify the difference between the Eaton and the Sundstrand? Does the Eton have the same tow valve as the Sundstrand? What do you do with the valve to allow pushing the tractor? Turn it a half turn left? Right? I'm sure the info is on this forum somewhere. I just can't seem to find it. Can someone point me in the right direction, please? 1 Share this post Link to post Share on other sites
kpinnc 14,571 #2 Posted September 4, 2021 (edited) Simplest way in my mind is this: All Eatons have a cam on top. Sundstrands do not. And no- Eatons do not have a tow valve. Anything on a bigger C series should have the 1100 (with hydraulic lift), which should freewheel. Just don't ever tow it. You can push it by hand, but no faster. Edited September 4, 2021 by kpinnc 4 Share this post Link to post Share on other sites
oliver2-44 10,679 #3 Posted September 4, 2021 Also a sunstrand transmission has the filter on the right side. The Eaton 1100 has the filter pointing out the back. The C165 would have a single cylinder Kohler engine and the C175 would have a 2 cylinder Kohler engine 3 Share this post Link to post Share on other sites
chipwitch 73 #4 Posted September 4, 2021 Great! Thanks to both of you! 1 Share this post Link to post Share on other sites
Maxwell-8 4,367 #5 Posted September 4, 2021 I jack the back up and put a dolly under it 1 Share this post Link to post Share on other sites
chipwitch 73 #6 Posted September 4, 2021 5 minutes ago, Maxwell-8 said: I jack the back up and put a dolly under it It was out in the middle of the field. 1 Share this post Link to post Share on other sites
c-series don 9,968 #7 Posted September 4, 2021 Another easy way to identify the transmission is the filter location. Eaton is on the End, Sunstrand is on the Side ! 1 Share this post Link to post Share on other sites
