tractorbeast 27 #1 Posted September 3, 2021 Looking for some advice on this steering system geometry and setup. I would think Someone has had to run into this steering issue I assume. Question is the angle at which the sector gear mesh or meets with the lower steering shaft teeth to teeth. I would think it to be 90 deg., but my first attempt leaves the sector gear at 0 or 180 deg. to the 94 deg., steering shaft. To me this doesn't seem correct.Both gear teeth are cut straight. Thanks so much for any help you can give me on this situation. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,353 #2 Posted September 3, 2021 Do you have the service manual? Share this post Link to post Share on other sites
tractorbeast 27 #3 Posted September 3, 2021 YES have manual Share this post Link to post Share on other sites
