TJ5208 1,841 #1 Posted September 3, 2021 Has anyone took a RD deck and mounted it on the back of a tractor i thought about doing something like that for Rebel. Just like a bigger tractor bush hog. Or has anyone just made something like a Bush hog. Share this post Link to post Share on other sites
Lee1977 7,744 #2 Posted September 3, 2021 I think it would do a lot better just to build a 36" or 40" Bush Hog. Single blades don't have the problems a multi blade decks have. Share this post Link to post Share on other sites
kpinnc 18,859 #3 Posted September 3, 2021 (edited) Anytime what you're cutting is high enough to be pushed down before making contact with the blade, the harder it is to cut. That's why the front of a bush hog is open. It provides the best chance of the blade making contact with grass or brush before pushing it down. If you want a bush hog, you'd need to cut the front off the deck you plan to use. Given how close the driver is to the ground on a Wheel Horse, any towed mower is dangerous. A bush hog will throw most anything it hits out to the front. It's a bad place to be... What makes bush hogs effective is also what makes them dangerous. If I were going to fab a bushog on a WH, I'd find or make a front mount. So long as it's used away from people, it's far safer on these little tractors. Just my two cents. Many operators of ATV type towed brush cutters have stitches or worse to prove my point. Edited September 3, 2021 by kpinnc 2 Share this post Link to post Share on other sites
8ntruck 9,184 #4 Posted September 3, 2021 I got a pretty good be use on the back of my calf once while bush hogging with an 8N. Somehow, the bush hog had packed up a baseball sized ball of grass and chucked it forward - right into the back of my leg. Many bush hogs have short sections of chain hanging on the front of the deck to slow down any debris thrown forward. Share this post Link to post Share on other sites
slim67 2,825 #5 Posted September 3, 2021 I’d like to see a custom flail mower for the back of one of these. I’ve used both and prefer the flail mower if given the choice. At least for the property where I work. 1 Share this post Link to post Share on other sites
pfrederi 21,005 #6 Posted September 3, 2021 You might want to start with a front mount mower. I use mine sort of like a bush hog. Since it gets to the stuff before the tractor has run over it knocking it down it does better job. Since it is out front you could cut off the front lip if the deck (Just don't tell OSHA) 3 Share this post Link to post Share on other sites
TJ5208 1,841 #7 Posted September 3, 2021 I thought it would be neat to do that I don't really like the deck on Rebel he ain't mine yet but get ahead on the stuff I need for him Share this post Link to post Share on other sites
TJ5208 1,841 #8 Posted September 3, 2021 Has anyone made something like a Bush hog Share this post Link to post Share on other sites
